> how do you fix a loose spoiler?
post Feb 12, 2013 - 9:59 PM
homebuilder
Joined Jul 22, '12
From SouthEast
Hi,
Looks like the bolt holding down my spoiler is broken. It is secure, but loose so it makes noise.
How would you suggest fixing it? How do you come off and are put back on properly?
I am attaching photos, one of the hole on the underside of the trunk, not sure if you can see, but it appears to be a bolt that is not secure. Also attaching a side view of the spoiler so you can see its loose.
This post has been edited by homebuilder: Feb 12, 2013 - 10:00 PM
post Feb 13, 2013 - 2:32 AM
Hanyo
Joined Aug 16, '03
From Bay area
the correct way to fix this is to take the spoiler off and drill and tap a new stud on the spoiler so you can bolt the spoiler back on.
if that is too much work. Go buy some automotive grade double side sticky tape and tape the spoiler back on. You can find this tape at autozone or orielys. look for the 3m tape.
post Feb 24, 2013 - 3:04 PM
homebuilder
Joined Jul 22, '12
From SouthEast
Thanks, how umm...exactly does the spoiler come off? I do not want to accidentally break it.
post Feb 24, 2013 - 3:26 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I see a lot of rust, that could be ugly when you take it off.
post Feb 24, 2013 - 6:54 PM
doctavic
Joined Jun 5, '12
From NJ
I got some really deep threaded hex bolts from Home Depot bigger than what was originally used.
post Feb 24, 2013 - 7:56 PM
homebuilder
Joined Jul 22, '12
From SouthEast
QUOTE (doctavic @ Feb 24, 2013 - 7:54 PM) *
How did you install them?
post Feb 26, 2013 - 2:26 AM
chacha
Joined Dec 29, '05
From So-Cal
you can always use threaded rivets...works for me...if you drill new holes, you might want to find bigger size rivets with the threading on the inside of the rivets.
post Feb 26, 2013 - 8:17 AM
Just take it off and seal holes
Lo-Fi Version Time is now: January 10th, 2025 - 7:33 AM
