Weird Idle Issues (Researched Already) |
Feb 13, 2013 - 6:42 PM |
Enthusiast Joined Jan 20, '13 From Los Angeles Currently Offline Reputation: 5 (100%) |
I have this weird idle issue.
Idle is either high, low or normal....at any random condition. It doesn't stall. When idle is high, I just rev the engine a little and Idle goes back to normal. Things I've replaced: Spark Plugs (OEM) Wire set (NGK) Cap/Rotor (OEM) Cleaned the TB Thermostat (OEM) Idle issue started after I replaced all of that ^ I want to clean the IACV but I can't seem to find it or I don't even know if it has one. ( Can someone post a picture of the engine bay and circle it, thank you) No codes. Passed Smog with flying colors. Ignition timing sits a 13* (I hope that's normal) Car runs fine. MPG is 25-27 combined. Today I'll reset the ECU (Pulling out the Hazard, EFI, ECU fuses). I also don't hear or see any vacuum leaks. Engine has 95k miles. MT I did search some posts but none reported back with a solution. Thank you. This post has been edited by 955SFE: Feb 13, 2013 - 6:42 PM -------------------- |
Feb 13, 2013 - 6:59 PM |
Enthusiast Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
-------------------- God made man....
Everything else... Made in China |
Feb 13, 2013 - 7:07 PM |
Thanks -------------------- |
Mar 14, 2013 - 12:49 PM |
Cleaned the IACV. IACV was dirty but it didn't solve my problem. I'll be checking the resistance/volts on the IACV and TPS this weekend. Any other suggestions?
Lo-Fi Version | Time is now: December 2nd, 2024 - 4:12 AM |
