> which starter?
post Feb 17, 2013 - 8:11 PM
celicaluva79
Joined Apr 6, '12
From south carolina
lookin for a used starter. i have a 96 5spd st. i keep finding 1.2kw and 1.4kw starters. which one do i need ? thanks
post Feb 17, 2013 - 11:00 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
5SFE engine lists a 1.4KW starter, 28011‑74070
post Feb 18, 2013 - 1:28 PM
celicaluva79
Joined Apr 6, '12
From south carolina
thanks for the response, unfortunatly i need the info for a 7afe. thanks tho!
post Feb 18, 2013 - 6:25 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Blink -- Looked at that several times, somehow kept skipping over the ST part.
What's wrong with your starter? They're often cheaper to rebuild than to replace, especially if the problem is the usual issue of worn contacts causing an intermittent single-click non-start. Those cost about $10 and a few minutes to swap.
post Feb 20, 2013 - 8:22 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
They're interchangeable. Get whichever, I suggest the higher power one.
Lo-Fi Version Time is now: January 9th, 2025 - 9:19 PM
