![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) ![]() |
engine: gen III 3sgte powered by autronic SM4 ecu, walbro fuel pump and stock injectors
This is my first time starting this engine since I bought all of the parts for it (formerly parted out), rebuilt it, and wired in the Autronic ecu. My engine starts and runs for about 5 seconds at a time and then it dies from a lack of fuel from the sound of it (not the fuel pump shutting off). I have a feeling it has something to do with the fuel pressure regulator. According to the vacuum diagram that I found in a google image search it doesn't need a vsv and it connects directly to the intake manifold, but I'm thinking that I need a vsv between it and the manifold. I am tempted to put on my AEM fuel pressure regulator that I have lying around but I would rather get the stock one running first and then work on getting the aftermarket one going. -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
think your barking up the wrong tree
stock fpr works fine without a vsv and i cant draw any correlation between a faulty fpr and running for 5 seconds and shutting off go back to your mechanical timing settings, wiring, fuel and ignition systems double check, then check all the datalogging and diagnostics you can on the ecu, if it has some type of idle learning process or setup for that then check over that, check over your fuel maps, etc when it does run, does it sound good or is it rough? -------------------- Mike W
think your barking up the wrong tree stock fpr works fine without a vsv and i cant draw any correlation between a faulty fpr and running for 5 seconds and shutting off go back to your mechanical timing settings, wiring, fuel and ignition systems double check, then check all the datalogging and diagnostics you can on the ecu, if it has some type of idle learning process or setup for that then check over that, check over your fuel maps, etc when it does run, does it sound good or is it rough? There is no idle learning process, I have to press the pedal a little bit at starting, I'll have to adjust the TB butterfly a little, but when it does run it runs good. Just hard to start. I have data logging off. -------------------- -Jay
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) ![]() |
Is your fuel pump resistor pack connected?
Is your fuel pump resistor pack connected? no, it's wired in to its own power source -------------------- -Jay
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) ![]() |
Idle air control valve connected under the throttle body ?
-------------------- st205 powered ss3 coupe
Yeah..that's connected. I'm going to play with the fuel map a bit and see what happens
I've traced down a faint ticking that is coming from the IACV. It is ticking like a madman. 10 times a second I would guess, if not faster. I know I have it configured right in the autronic. If I unplug it then the car runs for 3 seconds and dies the same as if it were plugged in. If my problem is the IACV, I can't even find where to get a new one.
Lo-Fi Version | Time is now: February 21st, 2025 - 12:28 PM |
