> Suspension travel
post Feb 25, 2013 - 3:45 AM
FWD-3SGTE
Joined Feb 8, '07
How much "travel" will a proper coilover have while cornering and hitting small bumps or dips on the road? I know it's an odd question but I feel that a proper coilover won't/shouldn't have hella travel. I ask this because the KSports on my 91 GT are very stiff when I try to "push" down on the car by hand but when I'm driving, corners and dips cause lots of travel and tire rub, I'd say alomost 2" of travel occurs sometimes. What do you think about that?
I'm researching coilovers for my 6th gen but I need to acquire some more knowledge on suspension characteristics before my purchase.
I also ask because I see a lot of fellas with a stance status but they don't seem to complain about tire rubbing too much, even the guys that poke their wheels or run them at the fender line but their tires don't get all cut up. lol.
I guess I can add to the question and ask about the differences between a cheap coilover and track made coilover. Thanks smile.gif
post Feb 25, 2013 - 9:06 AM
bsamps4
Joined May 16, '10
From Raleigh
you'll need to roll the fenders. my d2's travel about 2 inches as well. I could adjust them to travel less, but having some travel is a good thing.
post Feb 25, 2013 - 2:40 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
the correct terminology is suspension stroke.
all those coilovers listed above have compression adjustment and no rebound adjustment. rebound adjustment is only for a track type coilover. also each company puts a certain type of spring that best matches the shock itself.
i believe the only coilover track ready suspension available is k sport. call and ask them. if that coilover comes with both compression and rebound adjustment then you know its a track coilover.
also hotbits makes them for our cars but thats a custom order and would be around $1800.
post Mar 4, 2013 - 1:06 AM
FWD-3SGTE
Joined Feb 8, '07
Thanks for the reply in the difference between track suspension and normal street suspension.
Lo-Fi Version Time is now: January 10th, 2025 - 12:40 AM
