> tachometer wiring
post Mar 5, 2013 - 4:31 PM
match220
Joined May 13, '06
From Kaimuki, HI
Stock engine is out of the car, running a gen3 3sgte, car was previously 5sfe. I know which wire is the tach signal on the gauges (IG-), and which wire is at the igniter for the signal. I've been trying to run my tach off of the aftermarket computer that controls the engine now, but it doesn't output the right signal to run the tach. I would need an adapted. So no I'm looking into running the tach off of the new igniter ground. The problem is I now have 4 coils, and each coil has a built-in igniter. I can't pull the signal off of the igniter to give a signal to the tach, and I can't use the ecu signal without getting an adapter. Anyone have any more ideas?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Mar 5, 2013 - 4:48 PM
mkernz22
Joined May 10, '10
From MA
Buy an aftermarket tach that's compatible with the setup?
post Mar 5, 2013 - 4:50 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (mkernz22 @ Mar 5, 2013 - 11:48 AM) *
yeah, I guess I could do that and try to figure out how to shove it in my gauge cluster. I don't want my interior riddled with gauges..haha.
-Jay
post Mar 5, 2013 - 5:01 PM
match220
Joined May 13, '06
From Kaimuki, HI
hmm..OR I could buy a cheap set of 1.8t factory gauges off of ebay and swap out the tachs in the gauge cluster! smile.gif It even has a little clock in the RPM gauge
This post has been edited by match220: Mar 5, 2013 - 5:01 PM
-Jay
Lo-Fi Version Time is now: January 10th, 2025 - 6:28 AM
