Convert Top Adjustments |
Mar 11, 2013 - 11:15 PM |
Enthusiast Joined Aug 4, '11 From Texarkana Texas Currently Offline Reputation: 0 (0%) |
Does anyone know where (if any) the adjustments for the convertible top are? I know of the two hidden in the front upper corners but there must be others.
Mar 12, 2013 - 1:39 AM |
adjustments for? there are 2 at the base where the skeleton attaches to the body, but not much, what is ur issue
Mar 15, 2013 - 10:39 PM |
Doesnt line up at the top of the windshield or around the windows
Oct 21, 2013 - 12:22 PM |
Enthusiast Joined Oct 21, '13 From Redwood city Ca Currently Offline Reputation: 0 (0%) |
Sounds like I'm having the same issue (as a 'vert n00b). Frame doesn't sit straight when it's down, is crooked by an inch or two when it's just shy of being fully closed -- and a bit of a pain to wrestle with when getting the latches closed. Apologies if I've missed it in my searches, but any insights into any possible adjustments would be much appreciated. Thanks!
Oct 27, 2013 - 2:59 AM |
hard to see in this pic, there is a rubber stopper that works when you open the top at the base of the top skeleton. and there is also one on the other side when you close the top. only 2 adjustments you can do. if after this it does not align, the skeleton top is bent. or worst case scenario is car frame issue. not much to do sometimes if it has an aftermarket top, it may be too tight, thus preventing full closing, (nothing to do in here, fixing is a pain in the ass, as you have to realign the cloth, and that means dissasembly of the whole top) like the picture you see, and then fiddle with the aluminum bar, and restaple the cloth... you dont want to do that. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Oct 31, 2013 - 12:09 AM |
Enthusiast Joined Nov 13, '10 From Greenville, SC Currently Offline Reputation: 50 (100%) |
I transferred my redone top to my new Celica. And it doesn't sit quite right. But I noticed that the little plastic parts that it latches onto at the top of the window are pretty beat up. So I'd suggest checking those to make sure your latches going in correctly, or see if you can adjust the little hooks. It seems like you can, but I haven't fooled with it as I intended to get the plastic parts from my old car anyway.
Lo-Fi Version | Time is now: December 4th, 2024 - 7:07 PM |
