Enthusiast ![]() Joined Aug 30, '09 From Merced Currently Offline Reputation: 0 (0%) ![]() |
cant seem to figure out what this part is called recently broke it can anyone help?
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) ![]() |
The sensor itself or the harness?
-------------------- For Sale:OEM tail lights - make offer
Coolant temp sensor.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
that is the coolant temp sensor for the ECU. the one next to it is for the gauge
so does it onlu work when the water is cool?
just the senso..but if i replace this do i have to replace the whole harness? or can i just cut the wires?? oh and was wondering if i screw it off would water come out of there or would i have to drain somthing?
just the senso..but if i replace this do i have to replace the whole harness? or can i just cut the wires?? oh and was wondering if i screw it off would water come out of there or would i have to drain somthing? nah just plug it out. but with my experience it was too old and i broke it two time on different cars. the plastic was delicate. just be careful. plug it out and if i remember it should be a 17mm. i used a wrench and unscrew it. if the engine is cold and no pressure. it shouldnt come out. -------------------- For Sale:OEM tail lights - make offer
just the senso..but if i replace this do i have to replace the whole harness? or can i just cut the wires?? oh and was wondering if i screw it off would water come out of there or would i have to drain somthing? nah just plug it out. but with my experience it was too old and i broke it two time on different cars. the plastic was delicate. just be careful. plug it out and if i remember it should be a 17mm. i used a wrench and unscrew it. if the engine is cold and no pressure. it shouldnt come out. alrite kool thanks for the help everyone |
you are making a big deal out of nothing, what exactly is going on? if you need to replace the sensor just unplug the harness and swap it out. yes water is going to come out, not alot, but some will.
the sensor is constantly on, it provides the ECU the temperature of the coolant for enrichment and tuning -------------------- 2001 Celica GT-S Turbo
Lo-Fi Version | Time is now: February 18th, 2025 - 12:42 PM |
