WTB 96 gts liftback ecu |
Mar 17, 2013 - 5:51 PM |
Enthusiast Joined Mar 17, '13 From corpus christi, tx Currently Offline Reputation: 0 (0%) |
hi, i have a 96 gt 5spd liftback with a bad ecu - a potential buyer hooked up his battery charger/starter in reverse and burned it out. i'm the idiot for allowing him to do it unsupervised - i know. anyway the ecu is 89661-2d410. are there any other ecu's that are compatible? i know the 96 and later are obdII so it would have to be from a 96 to 99 maybe. i have seen others that are close. i found a california emmission ecu that is a 2d430 and was wondering if it is compatible. the other markings on the ecu are 5s-fe m/t. any help or suggestion would be appreciated. thanks.
Reason for edit: please remember to add 'WTB' in the topic title
Mar 17, 2013 - 7:34 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
Check your fuses first man. Ecu should be fuse protected. Also check relays
May 5, 2013 - 3:48 PM |
Lo-Fi Version | Time is now: December 2nd, 2024 - 3:59 AM |
