> Check Engine Light Code 12?
post Mar 17, 2013 - 7:22 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
My check engine light came on and I tested it. I got a code 12. I've researched it a bit and I think it means that no RPM signal going from the distributor to the ECU. Is that correct? How would I fix this?
This post has been edited by 1994Celica: Mar 17, 2013 - 9:37 PM
JDM Part King
post Mar 17, 2013 - 10:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
Probably means the distributor has eaten itself, as that's been the case every time I've seen someone with code 12. Take off the cap and give it a look.
2001 Miata LS 5-speed
post Mar 18, 2013 - 8:55 AM
seanb
Joined Aug 1, '11
From Illinois
+1. That's what it was when I had a code 12. It took out the coil as well. I was broke at the time, so I grabbed a junkyard distributor and a new coil. All was well after that. Check under the cap first as was mentioned above.
post Mar 26, 2013 - 3:51 PM
1994Celica
Joined Aug 5, '09
Ok I'm sure I need a distributor. Which brand should I go with Cardone or BECK/ARNLEY ?
JDM Part King
post Mar 26, 2013 - 4:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
Both are reputable brands, I suppose whichever is the cheaper of the two.
post Mar 26, 2013 - 7:56 PM
1994Celica
Joined Aug 5, '09
QUOTE (Box @ Mar 26, 2013 - 4:45 PM) *
I thought Cardone quality has fallen? Maybe I was mistaken.
JDM Part King
post Mar 26, 2013 - 9:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
I haven't heard of anything. I've used both brands before with no problems.
post Mar 28, 2013 - 8:56 AM
travisxcore
Joined Mar 24, '11
From 704
I got a remaned Toyota from O'Relieys for pretty cheap when my dizzy pickup chewed itself up. It was under the name Import Warehouse or something like that.
This post has been edited by travisxcore: Mar 28, 2013 - 8:58 AM
post Apr 13, 2013 - 4:13 PM
1994Celica
Joined Aug 5, '09
Relaxed distributor and coil, didn't shut off. Took it in and apparently it's the ecu.
JDM Part King
Lo-Fi Version Time is now: November 23rd, 2024 - 5:07 PM
