> Where do these wires go?, Never thought I'd make one if these threads haha
post Mar 22, 2013 - 12:15 AM
CelicaB
Joined Sep 24, '03
From Medina, OH
Trying to get a stripped Celica back on the road. I'm usually pretty good with wiring but I have no idea where to begin with this one. The turn signals and hazards work, the running light don't. I'm positive it has to do with where someone cut these wires. If anybody has a clue or pictures to where this plugs in at or where the cut wires go? Am i missing a piece after the cut wires? Thank you!!
The red and yellow cut wires coming out of the brown harness. The plug has pink and red wires.
It all comes out of this box, no distinct part number or markings.
post Mar 22, 2013 - 2:11 AM
XS1V
Joined Apr 22, '10
From Auckland, New Zealand
Keyless entry module is the black box. Cut wires coming from ignition are not factory so remove the piggyback clips. Two wire plug your holding looks like key illumination plug?
Brad
post Mar 22, 2013 - 8:55 AM
Malek
Joined Jan 26, '09
From Los Angeles
Man, I"m seeing Ohio pop up on the map! Where were all you guys when I was there?!
But yeah, black box is the keyless remote (should go under drivers seat) and I'll check later today about those plugs and report back. Unless someone beats me to it tongue.gif
post Mar 23, 2013 - 12:21 AM
CelicaB
Joined Sep 24, '03
From Medina, OH
I'm actually based out of Charlotte NC now I'm just too lazy to update my location.
Anyways I got a better picture so maybe someone could tell me where this plugs in at, I see nothing in the vicinity so that leads me to belive I'missing a part? It has a solid red and a solid pink wire coming of the plug.
I know it's the keyless entry module, everything on the car works but the front running lights. 4 ways work, turn saignals work, rear parking/ running light work, just no fronts when the headlights are set to one click or to on.
An someone mentioned it goes to the key ring, a picture, everything on the ignition is plugged in, and you see the two cut wires in the lower left.
Thank you guys for your help!
post Mar 23, 2013 - 1:04 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
I wouldn't suspect that to be the reason your front parking lights don't work. Those two piggybacks look like they are tied in to your 12V constant and ACC/HEATER/BLOWER wires, someone was using those feeds for something in the past, I would remove the piggybacks and forget it, whatever they were feeding was aftermarket.....(and improperly removed I might add, would have taken 30 extra seconds to rip them out and tape it up /installer rant)
Now the fact that your rear markers work and your front markers don't is interesting. They share the same fuse and circuit but different ground points, so the only way they would not work when the rears do is if the ground wasn't attached (besides just being burnt out) the front ones are grounded inside each respective fender.....trace them, or even easier test the socket with a multimeter, first look for 12V and GND on the two pins, then look for 12V on one pin and ground your other lead somewhere else...that will tell you right away if your ground is bad
That would be my first thoughts anyways.
As for the plug coming off the keyless entry module, it is probably for an option you don't have. I wouldn't worry about it, and I highly doubt it would affect your front marker lights
edit: found a schematic, changed my diagnosis
This post has been edited by schmooot: Mar 23, 2013 - 1:42 PM
ST205 Crew represent
Challenge Accepted
Lo-Fi Version Time is now: November 28th, 2024 - 12:36 PM
