> how to jack rear end up, i need the whole rear end up
post Jan 24, 2003 - 2:43 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
i have a jack and 2 jack stands but im not sure where to put them i needhelp fast, im hearing something loose in the back, i just got my car back from the shop and they raplaced the hub and all the arms and every thing else in the rear driver side wheel well now im hearn something shake wheni drive so i need to find out what it is. pleez help? confused.gif
post Jan 24, 2003 - 2:57 PM
bonzaisushi
Joined Oct 3, '02
could my sway bar in the rear just be breaking in?
post Jan 24, 2003 - 3:13 PM
Mynzeyes
From Franklin/Nashville, TN
what i do, is jack the car up by one of the rear tow-hooks. and once i get it up a little, i put a jackstand under the other...then, i let the jack down, then move the jack under the rear of the fram, you'll be able to see it. if your car is not lowered, you may be able to just go straight to that step, and slide the jack under there.
-John-
AIM==Mynzeyes
post Jan 24, 2003 - 3:14 PM
bonzaisushi
Joined Oct 3, '02
i got it but i cant figure what the sound is, i can bang on each of the rear tires and i hear this rattle it does it when i drive too
post Jan 24, 2003 - 3:17 PM
Mynzeyes
try grabbing the top part of the tire, and "wiggling it" back and forth. see if there's any play in it...
-John-
AIM==Mynzeyes
post Jan 24, 2003 - 3:38 PM
bonzaisushi
Joined Oct 3, '02
i figured it out its coming from my passenger side rear suspension my driver side suspension is new and my passenger side isnt so im tryn to figure out why im pretty sure its either my shock of spring
post Jan 24, 2003 - 5:36 PM
95STCelica
Joined Oct 12, '02
From New Jersey
i just backed mine up onto 2 ramps, had to have two people to keep their feet on the ramps to keep them from sliding..it was real weird, i didnt think ud be able to do it..but the ass sits higher than the front so i guess that's why it was so easy
post Jan 24, 2003 - 9:10 PM
Guest_Matthew_*
I'd take it back to the shop and tell them that it sounds like they didn't tighten something all the way. The should fix it for free. As long as they worked on something that the sound is coming from.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:09 PM
