mounting the cruise control actuator elsewhere? |
Mar 30, 2013 - 10:46 PM |
Enthusiast Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
Has anyone else considered mounting the cruise control actuator somewhere else? Below is what I have to work with..haha. I thought about cutting a hole in my custom airbox and mounting it sideways in there. Other than that I have that big gap area around the distributor and behind the intake piping, but I would need a shorter cable running to it from the firewall. What do you guys think?
-------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
Mar 30, 2013 - 11:07 PM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
Haha let me know if you figure something out because I just got rid of my actuator for my swap..
Mar 30, 2013 - 11:13 PM |
Haha let me know if you figure something out because I just got rid of my actuator for my swap.. roger... it's smaller than it seems once it's taken off of the metal mount that went under the battery tray. It's small enough for me to mount to the top of my turbo intake pipe, but I didn't want weight sitting on it and I couldn't get it to mount sturdily on a round pipe. -------------------- -Jay
Mar 30, 2013 - 11:35 PM |
you could mount it on the passenger side like the ST has it. just extend the wiring
Mar 30, 2013 - 11:47 PM |
you could mount it on the passenger side like the ST has it. just extend the wiring Oh yeah, there is a nice little gap over there between the coolant filler neck and the power steering reservoir. Anyone have pics of the 7a setup? I would also need the cruise control cable from the 7a ST though wouldn't I? -------------------- -Jay
Mar 31, 2013 - 6:09 AM |
you can mount it pretty much anywhere the cable will reach without kinking.
13.6@108MPH, 5SFTE Powered |
Mar 31, 2013 - 6:51 AM |
you could mount it on the passenger side like the ST has it. just extend the wiring Oh yeah, there is a nice little gap over there between the coolant filler neck and the power steering reservoir. Anyone have pics of the 7a setup? I would also need the cruise control cable from the 7a ST though wouldn't I? That gap is for the ABS, but does provide some room for you. The cruise control on a ST is located where the Power Steering Res is located. Shown below. Would be an interesting mounting, but I'm sure feasible! |
Mar 31, 2013 - 6:40 PM |
I am most definitely doing it, I'll just need to buy the cruise cable for a 7a celica and run it over to that side. The cruise cable for the 5s definitely won't reach. I don't have ABS so I have plenty of space for it.
Apr 1, 2013 - 6:43 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I re-mounted mine. Made a custom bracket for it. You can see it here in this picture. It's above the air filter, and to the right of the
blow off valve. -------------------- |
Apr 1, 2013 - 10:16 AM |
^^^^ dang its crowded in there
Apr 1, 2013 - 12:12 PM |
Apr 1, 2013 - 3:18 PM |
haha..at both of you. Yes that is very crowded. Unfortunately I made a battery mount there, as you can see in the side of my picture above. You mounted yours in the trunk I imagine? -------------------- -Jay
Apr 4, 2013 - 12:16 AM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
I relocated mine near the clutch master. Although there is very little clearance, it doesn't touch or rub on anything there. Uses the original GT cruise control cable. Only downside is not being able to run the plastic cover with it. I've had it like this for a few years now, and works great. No trouble with cable kinking at all.
Apr 4, 2013 - 12:28 AM |
I relocated mine near the clutch master. Although there is very little clearance, it doesn't touch or rub on anything there. Uses the original GT cruise control cable. Only downside is not being able to run the plastic cover with it. I've had it like this for a few years now, and works great. No trouble with cable kinking at all. that is an awesome place for it!! but I have an alarm horn there. I'm glad it fits, I can easily move the alarm horn somewhere else and put my cruise control there though. My cable will kink for sure, it has a bad spot in it that may make it kink. Is the wiring easily accessible from there to shorten it? Or does it run through the main loom to the passenger side? -------------------- -Jay
Apr 4, 2013 - 12:44 AM |
I relocated mine near the clutch master. Although there is very little clearance, it doesn't touch or rub on anything there. Uses the original GT cruise control cable. Only downside is not being able to run the plastic cover with it. I've had it like this for a few years now, and works great. No trouble with cable kinking at all. that is an awesome place for it!! but I have an alarm horn there. I'm glad it fits, I can easily move the alarm horn somewhere else and put my cruise control there though. My cable will kink for sure, it has a bad spot in it that may make it kink. Is the wiring easily accessible from there to shorten it? Or does it run through the main loom to the passenger side? Hmm, it's been awhile, but I'm pretty sure the factory cruise control wiring is run down the driver side, so it should be very simple to get the wiring where you need it to be. -------------------- |
Apr 4, 2013 - 6:44 AM |
I relocated mine near the clutch master. Although there is very little clearance, it doesn't touch or rub on anything there. Uses the original GT cruise control cable. Only downside is not being able to run the plastic cover with it. I've had it like this for a few years now, and works great. No trouble with cable kinking at all. that is an awesome place for it!! but I have an alarm horn there. I'm glad it fits, I can easily move the alarm horn somewhere else and put my cruise control there though. My cable will kink for sure, it has a bad spot in it that may make it kink. Is the wiring easily accessible from there to shorten it? Or does it run through the main loom to the passenger side? Hmm, it's been awhile, but I'm pretty sure the factory cruise control wiring is run down the driver side, so it should be very simple to get the wiring where you need it to be. yeah, my first thought was to extend the wires, but if they are running that way it would be easier to just tap into them back there. I think there is a bundle of wires with a yellow wire channel around them on that side. I'll look tomorrow. -------------------- -Jay
Apr 30, 2013 - 10:05 PM |
Enthusiast Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) |
heres mine. its not mounted yet but thats about where its going. |
May 1, 2013 - 12:14 AM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
no cruise control....no problem
-------------------- ST205 Crew represent
Challenge Accepted |
Lo-Fi Version | Time is now: November 25th, 2024 - 2:19 PM |
