> CD player scrambling issue
post Mar 31, 2013 - 9:48 AM
gts4
Joined Dec 20, '11
From gta
My cd player scrambles on occasion. It slows down the track, and this typically happens going over bumps. Getting it to work again is sporadic, and only happens on occasion after restart, hitting bumps, or 20 minutes later. Is this easy to diagnose?
Can I take it apart? How does the security code work?
Thanks!
This post has been edited by gts4: Mar 31, 2013 - 9:48 AM
post Apr 1, 2013 - 7:40 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (gts4 @ Mar 31, 2013 - 9:48 AM) *
Thanks!
Sounds like you need a new unit, unless you have the desire to pull the unit. Disassemble completely and most likely replace the laser module itself, check the bladders, and insure moving rails are not restricted. Even then, it could be an problem with an IC. This is line level repair...
I'd just buy a new unit for 50-150, get a face kit for 25, enjoy the new boom. Are you talking the OEM unit? Security code is new to me...
post Apr 4, 2013 - 8:10 PM
gts4
Joined Dec 20, '11
From gta
Cool. Thanks. It does say sec code if you hold 1 and 6 presets while turning it on. Try it. You can't use the radio until you power the vehicle on and off again. It also says anti-theft on the cassette opening.
QUOTE (rave2n @ Apr 1, 2013 - 8:40 AM) *
Thanks!
Lo-Fi Version Time is now: December 1st, 2024 - 10:14 PM
