Radio, Clock, Dome lights don't work!!! |
Apr 2, 2013 - 1:26 AM |
Enthusiast Joined Jul 29, '12 From Sacramento, California Currently Offline Reputation: 0 (0%) |
My car died a few months back, I just got it fixed recently & when I got her back the radio, clock, dome lights, door lights all don't work. I checked all the fuses and there still good. Does anyone know what the problem could be??? PLZ HELP!!!
Apr 2, 2013 - 1:40 AM |
Enthusiast Joined Apr 6, '12 From somewhere Currently Offline Reputation: 0 (0%) |
My car died a few months back, I just got it fixed recently & when I got her back the radio, clock, dome lights, door lights all don't work. I checked all the fuses and there still good. Does anyone know what the problem could be??? PLZ HELP!!! check the alt fuse its the big blue square one in the engine bay fuse box. btw im in Sacramento 2 |
Apr 6, 2013 - 10:02 PM |
My car died a few months back, I just got it fixed recently & when I got her back the radio, clock, dome lights, door lights all don't work. I checked all the fuses and there still good. Does anyone know what the problem could be??? PLZ HELP!!! check the alt fuse its the big blue square one in the engine bay fuse box. btw im in Sacramento 2 Nice! So is it the 100A one? Also my cig lighter went out yesterday I checked the 15A under the dash & its still good so idk what it could be? |
Apr 7, 2013 - 3:37 AM |
what kind of work did you do to your car before your problem showed up?
This post has been edited by mindkiller: Apr 7, 2013 - 3:39 AM |
Apr 9, 2013 - 12:20 AM |
what kind of work did you do to your car before your problem showed up? The water pump went out so it was parked for a few months. I had the timing belt water pump and power steering pump changed. I got it back and that's when the problem started. Everything worked fine before I parked the car for a few months. |
Apr 9, 2013 - 1:22 AM |
You might have some kind electric short some where, i remember before i had a short in my lighter that caused the clock, radio, dome light to stop working so i fixed the short and i had blown fuse 2, you should check every single fuse in your car again and check your grounds and check wires for shorts.
Apr 12, 2013 - 9:46 AM |
double check the fuses and relays, etc... also I remember a fuse labeled as "X" that I came across in the past that when I removed it that would turn off basically most of what you were mentioning. Worth a try, I just removed it because I wasn't sure what it was, till I lost all those radio, clock, etc. so I put it back and it came back on.
Lo-Fi Version | Time is now: November 26th, 2024 - 2:28 AM |
