21 Pages V  « < 9 10 11 12 13 > »
> Silly97- Nov 25, 2018 :SSFOUR Conversion finished. Pictures posted, Just to keep a record of my cars history. Nothing special. :)
post Nov 10, 2013 - 4:14 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (H8TRAIN @ Nov 10, 2013 - 9:24 AM) *
Those won't get more power. Are you interested in more? It's known that mild cams and tune get results. 6G96GT was telling me about his experience with the colt cams. Very positive. The cams and tune are technically not okay for smog. However, I think the car would run clean and throw no codes. I don't expect you to be a guinea pig for my hypothesis. I'm looking for an engine now. If I end up with a 5sfe I'll try the cams. I can see you are not one to worry about horsepower, but if I get a 5sfe and tune it I can keep you informed about the resources I use in the bay area and valley.
I've been thinking of throwing Webcams in my car actually. The only thing is how hard is it to install and uninstall for smogging? Like would I need to retune, replace shims, and cams just to pass smog? But keep me posted or shoot me your progression thread so I can keep updated about it.
post Nov 13, 2013 - 3:15 PM
ILoveMySilly97
Joined Mar 8, '12
Here's my exhaust sound clip take 2. Since the first fly by was ****ty. Lol.
http://www.youtube.com/watch?v=Q3prn7y9YpU
post Nov 14, 2013 - 1:07 AM
celicakitten
Joined May 30, '12
From CA/NV
QUOTE (ILoveMySilly97 @ Nov 13, 2013 - 4:15 PM) *
Nice! Car looks super clean, exhaust doesn't sound too bad either
2004 Celica GT-2zz w/6-speed swap
1999 Celica GT-3sgte swap
1993 Celica All-Trac
1997 Celica ST/Limited-rip
1993 Celica GT-rip my first love
post Nov 14, 2013 - 2:12 AM
ILoveMySilly97
Joined Mar 8, '12
Yeap. I love my exhaust. It's not loud or quiet. It's just about right. smile.gif
post Dec 18, 2013 - 12:31 AM
ILoveMySilly97
Joined Mar 8, '12
Small update on my next project. Going to plan to buy xxr 535 universal bolt pattern. After that ima do a bolt/hub conversion using my xxrs still. Sell my last set of 5x100 rims. Then buy my next set of 5x114 rims. Most likely some advan rims. smile.gif
post Dec 20, 2013 - 5:20 PM
ILoveMySilly97
Joined Mar 8, '12
Vinyl's installed!
I still got some up for sale if anyone's interested. $7 for one or $10 for a pair.
http://www.6gc.net/forums/index.php?showtopic=91414
post Dec 23, 2013 - 8:32 PM
ILoveMySilly97
Joined Mar 8, '12
Been reading up on them v6 swaps a lot lately and it's making me want to attempt one too. Started to go through Kurt95gt's and Smaay's swap threads and took some notes down. I'm debating if I want to attempt this yet. I'm don't have that much knowledge at engine work. The most complex thing I've done is swapped cv axles. Lol. I kept telling myself to wait until my clutch or my engine gives out first then start on the swap but we will see.
post Dec 24, 2013 - 8:26 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Id say read up on it just like youve been doing. And just go at it. Take it slowly and learn as you go!
エキサイティングカーレーシングチーム!
post Dec 24, 2013 - 12:47 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Tigawoods @ Dec 24, 2013 - 5:26 AM) *
Yea. Can't wait to get some power in my weak ass Celica. Lol.
ILoveMySilly97
Joined Mar 8, '12
post Dec 24, 2013 - 12:48 PM
Yeah, if this is not your daily then go for it. Plan for downtime
post Dec 24, 2013 - 3:09 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (njccmd2002 @ Dec 24, 2013 - 9:48 AM) *
This is my daily but my parents have an extra car so I'ma use that car while I'm building my v6. I should be able to get it up and running no longer than 1-3 months. Lol.
Smaay and Kurt95gt or any other v6 swappers. I've made a list with some questions. Hit me with other things I missed like parts or notes that I missed while reading your guys threads.
1mzfe v6 Into a St204 Swap
Parts needed:
97+ 1mzfe engine
-Rebuild?
-Replace timing belt and water pump
Engine harness needs rewiring(mr220v)
Ecu(MT ecu needed or AT ecu is fine?)
-Part number: 89661-06331
- Ground a pin to get MT
Custom passenger side engine mount(Smaay)
Custom y pipe(Smaay)
Upper Rad hose - 71203(Kurt95gt)
Lower Rad hose(Stock 1mzfe hose bolted onto a 90 degree hose? 3 chunks?)
Not needed but nice upgrades:
Light flywheel
-New flywheel bolts [Smaay]
-Pressure plate can be reused
New clutch(Southbend)
Short shifter
Notes:
AC Compressor
-Change puller or mod the top section
-welded -8 AN fittings
MT and AT rear headers are different
Needs to be CA SMOG Legal AKA BAR'd
Questions:
Ecu? AT 97+ camry ecu is fine but need to be mod to MT[Contact Smaay]
-NO immobilizer!
-97-98 ecu to avoid the EVAP system
-won't emit any AT codes so it should be CEL free also smoggable?
Fuel relay?[Kurt95gt]
Catylitc converters?
-1 cat after the y pipe
RPM meter? Tach needed?
-i4 stock tach can't read v6 signals?
Charcoal canister?
-needed for 97-98 1mzfe and 99-2002?
Coolant overflow tank?
-does it need relocation?(kurt95gt)
Throttle cable?
-Need ST throttle cables because GT are too long
References:
http://mr2oc.com/showthread.php?t=144375 MR2 CA BAR'd
http://www.6gc.net/forums/index.php?showtopic=82573 Smaay
http://www.6gc.net/forums/index.php?showtopic=82235 Kurt95gt PG25
http://www.6gc.net/forums/index.php?showtopic=91360 5sfe removal
http://car-part.com/ Search for 1mzfe
This post has been edited by ILoveMySilly97: Dec 24, 2013 - 3:17 PM
post Dec 24, 2013 - 10:12 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
The 97+ Camry ecu should work fine with a pin grounded out an the a/f sensors swapped for o2 sensors. The 97 Camry didn't have an immobilizer so no worries there. The 97 celica evap should be able to adapt to the 1mz an pass. But you'll have to ask smaay about that. Pretty Sure 97 will only needs a cat after the y pipe.
I'm using the stock Fuel relay from the 5s. Its connected to the mount for the 5s ecu. You have 3 options for the tach. 1) do what smaay did an swap a v6 tach into the stock cluster. 2) aftermarket tach like I did. 3) get a tach adapter to make the i4 tach work with the v6. The stock overflow tank will work.just need a
Longer hose to reach to the connection on the motor.
You'll need the st cable the gt cable is too long.
94 st hatch my daily driver
n
post Dec 24, 2013 - 10:38 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
The rear exhaust manifold for the my is adjusted to miss the motormount. The a/t manifold will work with some modding.
I'm working on a new idea for the lower rad hose. Just have to gets some time to try an figure it out. Smash might have a better hose then I do already.
The lightweight flywheel will be a nice upgrade
The flywheel bolt part number an website is in my thread or I'm sure smaay has it too. They are for the 2gr but work for the 1mz.
Southbend makes great clutches. I love mine with The 1mz. Holds the power very well but doesn't feel much stiffer than my stock clutch.
Can't wait to see you pull this off!
n
post Dec 27, 2013 - 2:52 PM
ILoveMySilly97
Joined Mar 8, '12
Ok. Updated my notes.
I'll need a 97 ecu to not worry about the immobilizer. I think I'll so smaays method for the tach. Since I don't want gauge pods.
post Jan 24, 2014 - 7:09 PM
ILoveMySilly97
Joined Mar 8, '12
Here's a teaser. I just picked these wheels up the other day. Plans are to polish it. And yes they're 5x114.3. You already know what that means. smile.gif
Advan SA3
17x8 +38
17x9 +32
5x114.3
post Jan 24, 2014 - 7:29 PM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
I dislike.... You have two sets of awesome silver wheels and as soon as I get to Cali to see them you get black ones -.-
post Jan 24, 2014 - 8:03 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (JoshuaM @ Jan 24, 2014 - 4:29 PM) *
Lol. You didn't read it right. Ima get the polished out before I even mount them. Black rims are just not my style. Lol. come take one of my sets home! Ill let you buy a set for cheap. Lol. I dont want my 5x100 rims anymore.
post Feb 7, 2014 - 12:19 AM
hoodedone
Joined Feb 20, '12
From Fresno CA
Just saw your album on facebook and have to say its a nice update from your first to last, i hope in the time i spend on it it looks just as good smile.gif
post Feb 7, 2014 - 12:26 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (hoodedone @ Feb 6, 2014 - 9:19 PM) *
Yea thanks. I put a lot into this Celica. Anything's possible with money and time. Lol.
Lo-Fi Version Time is now: November 25th, 2024 - 6:21 PM
