21 Pages V  « < 19 20 21
> Silly97- Nov 25, 2018 :SSFOUR Conversion finished. Pictures posted, Just to keep a record of my cars history. Nothing special. :)
post Nov 25, 2018 - 11:36 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (NgoFcukinWay @ Nov 25, 2018 - 6:39 PM) *
Did you do the 5X114 hub conversion?
Yea. I did it years ago. It was an easy swap. All bolt on.
post Nov 26, 2018 - 12:30 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
what exact parts did you use? I skimmed through one of the threads, but like the E153 thread, there wasn't really a clear answer that I was comfortable with. This would make getting my wheels a bit easier but would concern me about future BBK options.
-Alex {](O_o)[}
post Nov 26, 2018 - 2:41 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (NgoFcukinWay @ Nov 25, 2018 - 9:30 PM) *
It's simple. Assuming you don't have a ST.
For the front:
Use a 96-2000 RAV4 FWD hub and bearing(the RAV4 FWD uses the same part number for our GT Celicas so you can buy them separate or as a RAV4 kit which would be cheaper option). You can swap over to a 92-06 Camry V6(MUST BE V6) rotor or just re-drill your current stock ones to 5x114.3.
EVERYTHING else still uses the stock GT parts. Yea that includes bracket, caliper, pads, lines and etc.
For the rear:
Use 92-2001 Camry V6/i4(doesn't matter. Same part number) w/o ABS rear hub and bearing assembly. For the rotor either go with a 92-2001 Camry V6/I4(either or) rotor or just redrill your factory ones to 5x114.3.
This post has been edited by ILoveMySilly97: Nov 26, 2018 - 2:42 PM
post Nov 26, 2018 - 3:49 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
Hell yeah. you do man!
-Alex {](O_o)[}
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 11:05 AM
