3 Pages V  < 1 2 3 >
> apexi safc II tuning HELP!!
post Apr 7, 2013 - 3:40 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
so i raced a mustang today. and got my ass beat:( my car is just not what i know it can be. idon't know what to do. I've tried my best to tune it and its just not working out. when i go off the line my wastegate just opens up and my car bearly moves. but when I'm in third cruising then matt it then it will pull but not what it should be. i still can't get above 5grand rpm. any suggestions?
post Apr 7, 2013 - 9:05 AM
#1, dont post about street racing on this site, it'll get ya banned.
#2. tuning. you need it. ON A DYNO WHERE ITS SAFE TO DO SO.
how much boost you running?
post Apr 7, 2013 - 11:01 AM
Syaoran
Joined Jan 4, '12
From US
If your wastegate is opening you are reaching max boost. Having your wastegate open isn't a bad thing, as you're making it sound
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Apr 7, 2013 - 11:20 AM
Malek
Joined Jan 26, '09
From Los Angeles
QUOTE (brommy02 @ Apr 7, 2013 - 4:40 AM) *
so i raced a mustang today at my local drag strip because they are having test and tune. and got my ass beat:( my car is just not what i know it can be. idon't know what to do. I've tried my best to tune it and its just not working out. when i go off the line my wastegate just opens up and my car bearly moves. but when I'm in third cruising then matt it then it will pull but not what it should be. i still can't get above 5grand rpm. any suggestions?
Fixed it for ya! wink.gif haha
idk about your local forums but I know on mine, there's a few guys who are huge into tuning and may help you out..just a thought..
post Apr 7, 2013 - 11:47 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Ya but when my wastegate opens my car stops excelerating and fall's on its face. it doesn't open and continue to pull like it should. and i have no idea why its doing that
post Apr 7, 2013 - 12:11 PM
Syaoran
Joined Jan 4, '12
From US
But that's not the wastegate's fault, I just want you to realize that. The purpose of the wastegate is to bypass all excess exhaust gases out of your turbo so that they don't spin it any faster making more boost. If you didn't have a wastegate your turbo would never stop producing boost until it died or blew your engine.
As mentioned before, if you're limiting at 5000 RPM it's most probably because you're hitting fuel cut on the stock ECU. You need to clamp the MAP voltage (if you're using the stock MAP sensor) and/or get a 2-bar MAP sensor from an MR2 turbo. You need somebody to set your stuff up for you properly. While a SAFC may work to an extent, it's not ideal for controlling a non-factory turbocharged car.
post Apr 7, 2013 - 12:46 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
how do i clamp the map sensor
post Apr 7, 2013 - 1:13 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
first off what are you using for a MAP sensor? if you are on the stock sensor, thats going to be a big problem there
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 7, 2013 - 3:09 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (brommy02 @ Apr 7, 2013 - 1:46 PM) *
You first have to find out if you have a stock MAP sensor or a 3SGTE MAP sensor.
If it's still the stock MAP, you need to get a 3SGTE MAP sensor to run 14PSI of boost or less.
post Apr 7, 2013 - 5:55 PM
brommy02
Joined Apr 2, '13
From bluffton I.N.
is there a way i can tell by looking at it.
post Apr 7, 2013 - 7:48 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (brommy02 @ Apr 7, 2013 - 6:55 PM) *
This is a 3sgte MAP sensor:
This is a 5sfe stock MAP sensor:
I believe the main visual difference is the sticker on it (it has a part number on the sticker which you could use to tell which one it is)
post Apr 9, 2013 - 1:09 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Where is this located. because there is nothing that looks like this by the throttle body
post Apr 9, 2013 - 6:24 AM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (brommy02 @ Apr 9, 2013 - 2:09 AM) *
it should be mounted to the firewall somewhere behind the intake manifold IIRC.
This post has been edited by Ted95: Apr 9, 2013 - 8:48 AM
st205 powered ss3 coupe
post Apr 9, 2013 - 8:33 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
i only found one sensor attached to the firewall and it doesn't look anything like the ones in the picture
post Apr 9, 2013 - 8:43 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
here it is, its right next to the windshield wiper motor, ignore the black box below it.
post Apr 9, 2013 - 8:54 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
ya that's the one i saw but it doesn't look like the one in the pic above. how do i tell if it's.the one for the 3sgte or the 5sfe
post Apr 9, 2013 - 10:58 AM
mkernz22
Joined May 10, '10
From MA
get us a picture of it
post Apr 9, 2013 - 11:35 AM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (Syaoran @ Apr 7, 2013 - 8:48 PM) *
QUOTE (brommy02 @ Apr 9, 2013 - 9:54 AM) *
^^ it doesn't have one of these stickers on it?
This post has been edited by Ted95: Apr 9, 2013 - 11:36 AM
post Apr 9, 2013 - 9:27 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (presure2 @ Apr 6, 2013 - 1:59 PM) *
ok so, when your just driving around, not in boost, youll want to tune the lo map till your a/f gauge bounces around 14.7-15:1, and tune the high map for when your in boost so that the a/f is right about 11.5:1 . if your anything richer than 11:1 under boost, your wasting gas, and leaving alot of power on the table.
how much boost are you running, and do you have a water injection kit?
if you want the setup to last, i would strongly suggest not running more than 14-15psi, and get a water injection kit on there with a 3 or 5gph nozzle asap.
with the WI, and a decent tune, the car should pull hard, and will last a good long time, provided you take care of it.
I echo this..I was going to say the same thing..be careful though, running too lean with a turbo will end up overheating your turbo..here is a nice little chart for you, ignore the right two columns. I would try to find out why it started running rich first though.
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Apr 10, 2013 - 1:01 AM
brommy02
Joined Apr 2, '13
From bluffton I.N.
Ya but none of the numbers are the same is blue tho
3 Pages V  < 1 2 3 >
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 15th, 2025 - 10:43 AM
