2 Pages V  < 1 2
> Spacers for 60$? Precision European Motorwerks, Are they safe?
post May 15, 2013 - 9:36 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Red123 @ May 15, 2013 - 4:30 PM) *
I've bought those items:
http://www.ebay.com/itm/380629216968?ssPag...984.m1439.l2649
http://www.amazon.com/Hubcentric-Spacers-C...erks+5X100+54.1
yesterday I drilled the front wheels and it's ok now I think. even on high speed. no extra handling problems.
Yeap. The reason why the front ones had to be drilled was because it was 20mm, if it was 25mm like your rear then you would've been fine. 25mm clears your whole stock stud while the 20mm is not thick enough to clear the stock studs.
post May 15, 2013 - 10:10 PM
Red123
Joined Oct 25, '11
From Tbilisi
QUOTE (ILoveMySilly97 @ May 15, 2013 - 9:36 PM) *
well said. the problem was really that. First I was thinking to cut the studs of the spacers (couple of mms), but I was not sure how safe it would be.
post May 15, 2013 - 11:23 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Red123 @ May 15, 2013 - 11:10 PM) *
You'd want to cut the studs down on your car, not the ones on the spacer.
I did it on my car and it's perfectly fine
This post has been edited by mkernz22: May 15, 2013 - 11:26 PM
post May 16, 2013 - 12:10 AM
ILoveMySilly97
Joined Mar 8, '12
Exactly what mkernz22 said. It's the stock stud that's the problem and not the studs on the spacer. It's safe to have them cute/shaved as long as the lug nuts or nut is able to grab onto most of the threads.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 4th, 2024 - 11:40 AM
