> Major Service - What would you do?, What would you replace?
post Apr 11, 2013 - 5:15 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Hey Guys,
Apart from all the JDM goodies on order, it is time to do some general maintenance on the car too. I bought the car a year ago with 141,000kms, and it just clicked over to 154,000kms. I had the timing belt replaced when I bought it, and I have done one simple oil and filter change in this period (probably about 8 months and 5,000kms ago, so definately time for another one). I am planning on changing the oil and filter again tomorrow, but I wanted to do a comprehensive service very soon, as although I know the car had been serviced regularly, I have a suspicion it hasn't been by the log book specifications.
I have just bought some NKG Iridium IX spark plugs, and I am also planning on changing the fuel filter and the manual transmission fluid (getting the grinds). I just wanted to ask what else would you do to keep the engine in top shape, without know what had been changed when?
Thanks,
P.s. also, this is as good a time to ask as any, my radiator has green fluid in it, although there are rusty coloured edges on all of the plastics around the cap. Does this mean the car just started off with red coolant and it stained, or do I have rust in there? And is this a problem? (I have no heating problems whatsoever, no matter how I treat it it always sits dead centre on the gauge!)
post Apr 11, 2013 - 6:16 AM
change what u said and flush the radiator. The green fluid is just probably green coolant.
You have to realized after 10 years, who really cares about following the logbook. People do it when they remember. Toyota red coolant is great, but on the new cars, not on ours. Any coolant will be fine. oil and tranny oil, may be a different case.
just read in the forums and get an idea... there are a lot of posts regarding general maintenance
post Apr 11, 2013 - 2:01 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
To keep the engine in top shape? Just do a full tune up and do it yourself. It will save you loads of money.
I'd recommend you to change your motor oil once every 3 months or 3,000miles, semi-synthetic every 4 months or 4,000 miles, fully synthetic every 5-6 months or 5-6,000miles. Depending on what kind of oil you use. I would never go more than half a year without changing my oil.
post Apr 11, 2013 - 6:07 PM
JoshuaM
Joined Mar 6, '12
QUOTE (njccmd2002 @ Apr 11, 2013 - 7:16 AM) *
Yeah, I realized that, which is why I was trying to gage interest in what everybody here thought was worthwhile. Thank you for the heads-up on the coolant front smile.gif
QUOTE (ILoveMySilly97 @ Apr 11, 2013 - 3:01 PM) *
Haha, yeah I'm definately doing it all myself, the only thing I had changed for me was the timing belt, and that was only because the dealer was paying to put a new bearing kit or something in that water pump, and I asked them to fit a new timing belt at the same time (so I only paid for the cost of the belt) - and it was nice to have it all done before I drove the 1200 miles home tongue.gif
I don't understand getting routine services done at a mechanic, my friend had his done on Wednesday; he paid $220 for oil, filter, air filter and wiper blades from a mechanic for his Mazda 121 metro economy car. What a complete waste of money! tongue.gif We had even offered multiple times to help him and show him how to do it, but some people just don't want to touch them.
My plan for services was 6 months or 3000 miles, and I always use semi-synthetic. Life just got away from me a bit on this occasion.
post Apr 11, 2013 - 7:01 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Check all the wheel bearings, bushings, spark plug wires, dizzy cap and rotor, replace power steering fluid.
Some of the least looked at stuff will cause the most annoying sounds.
post Apr 11, 2013 - 7:58 PM
JoshuaM
Joined Mar 6, '12
QUOTE (soulshadow @ Apr 11, 2013 - 8:01 PM) *
I forgot to mention that the dizzy cap is coming off, I've had an oil leak from there since I bought it. Had it 'repaired' twice at the dealer's expense, but still no luck. I'm guessing they only changed the outer seal, so going to give it a go at changing in inner one as well, and check out the cap when I'm at it. I have been told that this could be why my fuel consumption isn't great (22 MPG no matter what driving style or conditions), and it certainly isn't great for the engine tongue.gif
post Apr 11, 2013 - 11:02 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I don't know about the dizzies but some requires a whole new dizzy order to get rid of that leak since the seal is internal and impossible to disassemble.
post Apr 11, 2013 - 11:59 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (soulshadow @ Apr 11, 2013 - 9:02 PM) *
Yeap. If your replacing the inner seal. You might as well rebuild it. and for the power steering fluid, brake fluid, and manual transmission fluids. Those aren't recommended to be changed because they should last the whole life of the car. But then again you can change them if you want. Just a FYI, it CAN make things worse.
post Apr 12, 2013 - 9:27 AM
trdproven
Joined Aug 2, '05
From Guam
^ your car looks much better btw, just need projectahz.
to the OP, just search around for tune ups in the forum. sure it was covered a good number of times.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 12, 2013 - 9:48 AM
JoshuaM
Joined Mar 6, '12
And whilst searching for dizzy rebuild threads I found all the general maintenance ones - don't know what I was searching for last time tongue.gif
And transmission fluid definately needs replacing (or actually fixing the sychros), I'm just having the grinds in 3rd gear like everybody else.
This post has been edited by JoshuaM: Apr 12, 2013 - 9:50 AM
post Apr 12, 2013 - 6:27 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (trdproven @ Apr 12, 2013 - 7:27 AM) *
Thanks. Agreed. Got to start on my gt4 rear splits repaint then I'll go for the projectors. wink.gif
QUOTE (JoshuaM @ Apr 12, 2013 - 7:48 AM) *
I have the same thing. I bought 3qt of Pennzoil synchromesh and couldn't remove the filler nut. Lol. Bummer. Also lube shops won't change them for you if they're over 150k miles. So if you want a shop to do it, take it to a transmission shop. Though id recommend you do it yourself. Save some serious money. wink.gif
Lo-Fi Version Time is now: November 29th, 2024 - 10:43 AM
