> Intakes?
post Apr 14, 2013 - 6:15 AM
aldizzurp
Joined Oct 5, '12
From Los Angeles, CA
Sups guys,
Looking to buy an intake for the celica vert and was wondering what's a great brand to get for a reasonable price.
What kind of intakes are you guys running and how well is the performance/mpg?
Thanks!
post Apr 14, 2013 - 11:54 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I have a 5sfe and the only branded aftermarket intake I know of is the weaponR dragon intake or the injen shortram. It gave me better throttle response but there weren't any noticeable power Or mileage difference.
post Apr 15, 2013 - 5:26 AM
trdproven
Joined Aug 2, '05
From Guam
I made my apexi one from the weapon r pipe and then an apexi filter Required two couplers though instead of 1
This post has been edited by trdproven: Apr 15, 2013 - 5:27 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 15, 2013 - 9:39 AM
travisxcore
Joined Mar 24, '11
From 704
I like my weaponR but I just don't like how close it sits to the battery and the fact that its hardly pointed towards the hole where the air flows in. Haha.
post Apr 15, 2013 - 11:56 AM
PaddyTapps
Joined Mar 6, '13
From Tampa
I ordered the $28 one off ebay and will probably switch filters depending on quality plus it had free shipping. Going to custom build a cold air box as shown in the how-tos.
post Apr 15, 2013 - 1:59 PM
Box
Joined Feb 23, '12
From Warrior, AL
The only way you're going to maintain power is to make a cold air box to go with it, that or move the filter down into the fender arch. The best option for making power would be to put the filter in an area where cold air is forced into it. Though that'd require body modification or putting the filter in an area susceptible to sucking in water. With a stock 5S those gains would be marginal at best and not worth it. Believe it or not the people who designed all of these cars knew what they were doing. If you think about it the stock units are cold air boxes, but with a panel filter. Most factory boxes even have ducting that draws air from the bottom of the car. So contrary to popular belief, odds are you're better off with the factory intake. More noise doesn't equate to more power. If you're just wanting the sound you can remove the resonator.
2001 Miata LS 5-speed
post Apr 15, 2013 - 2:11 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ Apr 15, 2013 - 11:59 AM) *
^What he said. Majority of the time factory intakes are the best for most cars. The only way you'll get some power out of a 5s is mod the cams along with I/H/E. Or go turbod. The weak spot of our 5s is in the intake and exhaust ports. Something we can't really mod.
post Apr 17, 2013 - 1:12 AM
aldizzurp
Joined Oct 5, '12
Thanks for the quick responses guys!
So basically getting an aftermarket intake is a little useless unless you're modding the above mentioned.. In regards to more power..
& the same for exhausts..
As to a really good (not ricey sounding) deep sound, what exhausts are you guys running?
post Apr 17, 2013 - 2:25 AM
Box
Joined Feb 23, '12
From Warrior, AL
Magnaflow or Flowmaster in the stock diameter would make for a good sound, well as good as a 4 cylinder will sound anyway. I personally plan on using Magnaflow if I ever do the exhaust on mine. Your options would be a straight through muffler or something with baffles. Obviously a straight through would provide for better performance, but something with baffles is better at removing rasp that is ever so present in 4 cylinder engines. Either way as long as you stick with Magnaflow or Flowmaster and stay the hell away from all of the fart cannons you'll be ok.
Lo-Fi Version Time is now: November 27th, 2024 - 2:56 AM
