FT: 20mm Bolt on spacers for non bolt on spacer |
Apr 14, 2013 - 10:35 PM |
Looking to trade two 20mm bolt on spacers for two 20mm non bolt on spacers.
Reason being is that I have extended studs in the rear for the 15mm I currently have on and I needed the 20mm with the 15mm so my car wouldn't rub with the winter tires I had. Now I want to space out my tires some more, but can't because the GT4 wheels don't have another set of holes so the studs will start to press into them if I use the 20mm bolt on spacers. The 20mm's that I have are 5x100 and hubcentric. Looking to trade for the same thing, just non bolt on. Thanks. |
Apr 14, 2013 - 11:25 PM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
How hard was it to install the extended studs? I will have to do that for mine because my OZs don't have the extra holes in the back either..
Sorry for the offtopic haha good luck with your search! -------------------- |
Apr 14, 2013 - 11:53 PM |
Well if you have the stock studs, you don't need to worry about the wheel hitting the studs because the stock ones are short enough.
I, on the other hand, already have the extended studs in the rear. So it's either I swap out the studs and put the bolts on spacers on or get non bolt on spacers. |
Apr 15, 2013 - 12:14 AM |
It's the nuts that hold the spacer to the hub that hits my wheels..They don't sit flush with the spacer. I was just wondering how much of a pain it is to swap studs on a 6th gen..
Apr 15, 2013 - 6:19 AM |
all you need is the hammer of thor to knock them out. and some pb blaster
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 15, 2013 - 11:00 AM |
Apr 16, 2013 - 5:16 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
I actually used a house hammer. Lol. Used a I think it was 2-5lb hammer for all 20 studs with no problem. Hardest part was installing because I didn't have an impact gun. -_-"
Apr 16, 2013 - 8:38 AM |
I actually used a house hammer. Lol. Used a I think it was 2-5lb hammer for all 20 studs with no problem. Hardest part was installing because I didn't have an impact gun. -_-" Yeah, that's what I used to get all my studs out. Then I used a breaker bar so the hub wouldn't spin and a washer, socket, washer, wheel nut combo on each of the studs to get them on. It actually wasn't too bad of a setup for when I put the entended studs on |
Lo-Fi Version | Time is now: December 1st, 2024 - 7:35 PM |
