> Any guide to How to replace rear top shock mounts?
post Apr 16, 2013 - 2:08 PM
johndps
Joined Jul 6, '06
From Paisley, Scotland
Hi guys.
Is there a guide on the forum on how to replace the rear top shock mounts?
Top damper mounts?
My poor wee Celica gen 6 convertible is clunking from the left rear.
Is there anything that can be done with the old one to refurbish or is it case of only a replacemnet will do?
Thanks.
post Apr 16, 2013 - 3:03 PM
mkernz22
Joined May 10, '10
From MA
You'll need an impact gun and two spring compressors, to start off.
You'll start by taking the strut off the car. 3 bolts up top, 2 on the bottom and 1 for the sway bar (which you'll want to replace the endlinks when you do this).
Once it's off, you put the compressors on the spring and tighten it down till it's not touching the top mount anymore. Then take the impact gun to the bolt on the top and it's off. Then just go in reverse order to put it back together.
That is how I would do it. There is a trick I have to doing it without the impact gun though.
post Apr 16, 2013 - 3:19 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (mkernz22 @ Apr 16, 2013 - 4:03 PM) *
Rears are not under load and do not require spring compressors.
post Apr 16, 2013 - 3:41 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (rave2n @ Apr 16, 2013 - 4:19 PM) *
Well, better to be safe than sorry.
post Apr 16, 2013 - 9:12 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (mkernz22 @ Apr 16, 2013 - 4:41 PM) *
Won't be less safe nor sorry. The rear springs don't shoot out from their perches like the fronts do, but it's always a good rule of thumb.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Apr 18, 2013 - 2:15 PM
czwalga
Joined Sep 27, '10
From pittsburgh
I've taken the front and rears apart without spring compressors.... even though I have them. laugh.gif
Rears pretty much just have like 1/2" of preload, which is nothing. The fronts have maybe 1.5" but still not bad. Small kick, nothing dangerous.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Apr 18, 2013 - 7:29 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
I always advocate spring compressors -- I'd rather be bored than get a surprise. It's the unlikely and unanticipated that gets people hurt.
However, for the OP: are you certain it's the strut mount that's causing the clunk? The Celica's rear suspension is notorious for a very specific failure, that of the No. 2 suspension arm outboard bearing, which causes a clunk. The suspension arms are the shorter bars running in pairs from the middle of the chassis laterally to the rear wheels, sometimes referred to as lateral links or (erroneously) as rear control arms. The forward of each pair is the No. 1 arm, while the rearward of each pair -- the one with the threaded toe adjuster on the shaft -- is the No. 2 arm. http://www.6gc.net/forums/index.php?showtopic=35515&st=0 You can test for this by getting the vehicle up on a ramp or lift and manipulating the suspension -- use your ears to trace the noise or hands to trace the vibration. Alternately, you can often get the bearing to react by prying at the bar.
Another common source of clunking -- rathe than creaking or groaning -- is worn out stabilizer bar bushings. These are also a cheap fix, and easy to test since you can disconnect the stabilizer bar from these bushings and then manipulate the suspension.
Strut changer how-to: http://www.turbomr2.com/MR2/HowTo/Suspensi...ringStrut-1.HTM
This post has been edited by Galcobar: Apr 18, 2013 - 7:30 PM
post Apr 18, 2013 - 9:51 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I've shot out the top mount before and lets just say it left a pretty nasty chip on a cement floor that was the size of a half dollar. Imagine if that was you skull!
post Apr 18, 2013 - 10:39 PM
doctavic
Joined Jun 5, '12
From NJ
I used Autozone's loan-a-tool service and got the coil spring compressor tool, but didn't really need it on the rears. Especially to put my TRD springs on. They were pretty loose on the rear struts.
Lo-Fi Version Time is now: November 25th, 2024 - 9:35 PM
