> Need your help with AFR on 2nd gen 3sgte swap
post Apr 19, 2013 - 12:25 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
94 celica gt with 2nd gen 3sgte swap. Everything is stock with AEM EMS. Harness done by Dr.Tweak. The AFR would read 14-15 from cold start but when it starts to warm up it would gradually move to 16-17. Is this normal? Here is a short video of it. Any clues or suggestions would help Thanks in advance
http://www.youtube.com/watch?v=Bic419UjtsE
post Apr 19, 2013 - 1:50 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
my second gen does this too
post Apr 19, 2013 - 2:03 PM
team_omega
Joined Aug 14, '05
QUOTE (garin @ Apr 19, 2013 - 1:50 PM) *
Is it normal or is it not supose to do that?
post Apr 19, 2013 - 2:41 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
im not sure my car smells rich... but i still get 20mpg.
post Apr 19, 2013 - 8:13 PM
No its not normal.
Two main things that will cause this are:
1. You have a pretty big Vac leak.
2. You have an exhaust leak/crack or you are running open downpipe.
If both of those check out, then you need to take a look at your mechanical timing as well as your ignition timing.
Its also possible that there is something setup incorrectly with your AEM. Also assuming that you don't have some huge aftermarket cams installed.
This post has been edited by lagos: Apr 19, 2013 - 8:15 PM
post Apr 19, 2013 - 8:57 PM
team_omega
Joined Aug 14, '05
Thanks lagos I will check on that sometime this week as the car is just stored in the garage as of now.
post Apr 20, 2013 - 7:48 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
my problem is not vacuum. it reads 18-22 inhg at idle.
post Apr 20, 2013 - 11:32 AM
QUOTE (garin @ Apr 20, 2013 - 8:48 AM) *
Then work your way down the list I posted and check your exhaust and mechanical timing.
But whenever I have a vac leak, even a small one, I first notice it as a lean reading on the wideband.
I was just dealing with this issue last week. At idle I was very lean, while at cruising it was fine and my vac readings were about 18inhg. Poking around the engine bay I first found that a small vac cap that I was using on my AC Idle up valve had blown off. I fixed that, and now my car was idling at about 16 afr. Then I did some more investigating and found that my downpipe is starting to develop a small crack right next to the factory o2 sensor. I wrapped the crack in some exhaust heat wrap and put a clamp around it. Now im back to a 14.7 idle. So in my case, it was two issues that caused it.
You also have to remember that on a 2nd gen 3sgte, a "vac leak" means any air leak past the AFM. So the problem could also be cause by a leak in your intake piping.
This post has been edited by lagos: Apr 20, 2013 - 11:38 AM
post Apr 22, 2013 - 4:19 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (lagos @ Apr 20, 2013 - 12:32 PM) *
yes good advice
Lo-Fi Version Time is now: November 29th, 2024 - 8:06 AM
