> steering, serios stearing issue
post Apr 20, 2013 - 2:14 AM
tuner9069
Joined May 20, '12
From motown,wv
When driving the celica at any speeds aspecially at higher speeds the entire car shakes and the steering wheel shakes irradically.
post Apr 20, 2013 - 4:18 AM
b22ri22an
Joined Jun 2, '10
From Davenport, Florida
QUOTE (tuner9069 @ Apr 20, 2013 - 3:14 AM) *
check your front tires for a "bubble" on the road surface of the tire. if some of the steel belts inside one of the tires snapped it will produce a bubble in the tire that will cause extreme vibration while driving, the faster you go the more the car will shake
post Apr 29, 2013 - 3:14 PM
aldizzurp
Joined Oct 5, '12
From Los Angeles, CA
Had this same problem a month ago so I took it to the shop. My front tires were wearing off irregularly from the inside which I couldn't see. Changed the front two tires and it fixed the problem.
post Apr 29, 2013 - 5:26 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Have your tires balanced and have the alignment checked. Just did mine yesterday cause steering wheel is shaking intermittently on highway speeds. Turns out that the wheel is off balance but the alignment is good.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: November 29th, 2024 - 5:26 AM
