Enthusiast ![]() ![]() Joined Aug 4, '06 From Toronto Currently Offline Reputation: 0 (0%) ![]() |
Looking for some help i have coilovers looking at the xxr 521 16x8 et20
would they fit are celica ?? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
I'm going to be running a XXR 002 16x8 ET0
Yeah, they'll fit hahaha. Make sure you get a 5x100 lug pattern. Also, the rear will be in a bit most likely, front will fit right to the fenders. My 0's stick out past the fenders. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
yea i was thinking the front would be just flush or stick out a bit
nice wel is that or the 527 17x8.25 et35 rear 25 |
I never recommend a staggered setup as it makes it impossible to rotate your wheels. However, it does look nice... so more power to you if you want to do that. 25 in the rear would sit pretty close to flush and 35 in the front at 8.25 would also sit pretty decent. Personally, I like the 527's better for a Celica. The 521's look like stock GTi BBS's and aren't that cool IMO.
Wrap the 527's in a 215/40/17 or a 205/45/17 and they'll stretch nice too ![]() http://tyrestretch.com/ is your BFF when it comes to tire fitment. ![]() This post has been edited by RabidTRD: Apr 22, 2013 - 5:38 PM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
You think i would need to fender roll at all with the 527 ?
good point on the rotate maybe do 35mm all around |
You'll have to do fender roll in the rear if you planning on slamming it. Otherwise, you may be okay.
35 and you could run spacers if you wanted to make it work a bit better. 35 in an 8.25 should sit pretty. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
right now the coilover should give me a bit more room
dont think i will be slamming it |
Lo-Fi Version | Time is now: February 18th, 2025 - 1:31 PM |
