> misfire..how reliable are the genIII injectors?
post Apr 22, 2013 - 7:28 PM
match220
Joined May 13, '06
From Kaimuki, HI
Ok, to keep things simple in my explanation. Car is a celica with a swapped genIII 3sgte, running aftermarket ecu and individual coils from a 00 audi 1.8t. Coils have built in igniters and my wiring is solid, everything is soldered, heatshrinked, and taped together.
problem: misfire is completely random but seems to be heat triggered. When the car has been running long enough to get pretty toasty it starts misfiring (sometimes, not all the time). Sometimes one cyl, other times two cyls.
my ecu isn't triggering a misfire error when I have the laptop plugged in, I think because it isn't happening often enough to trigger an error. I'm suspecting the coils because they are known to be sucky, AND the 99/00 audi a4 1.8t coils that I have are supposed to be the most reliable year coils. According to the audi guys the stock ones are better and more reliable than any aftermarket replacements, so I'll stick with the stockies.
Just to cover all bases, I thought I would ask how reliable the genIII stock injectors are. I haven't heard of any problems with them looking through the forums, but I'm asking anyway. Even though I'm 90% sure my coils are to blame frown.gif
I love these coils because of the hot spark they are known to deliver.
A side note though: I wish I could record how the engine sounds when it is misfiring. It is running on two cyls, and is slow compared to normal, but sounds just like an impreza. It sounds really throaty and cool. So I know it's either coils 1 and 4 or 2 and 3 since the engine sounds "normal" (normal for an impreza) when running on two cyls and those cyl pairs are the only way it can run like this and sound semi-normal.
This post has been edited by match220: Apr 22, 2013 - 7:31 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Apr 23, 2013 - 11:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i would say they are as reliable and any other injector. but anything is possible and parts do fail
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 23, 2013 - 12:07 PM
If you had an injector problem, it would show up on your wideband.
post Apr 24, 2013 - 4:38 AM
onnaj
Joined Sep 6, '12
From Holland
Could be lot's of problem. Maybe the EGT sensor will recieve to high values? Remembered an other post where someone had the same problem.
Try to disconnect it and see if the problem still occurs.
post Apr 24, 2013 - 2:25 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (onnaj @ Apr 23, 2013 - 11:38 PM) *
I don't have an EGT sensor on mine. With the aftermarket ecu I am only using necessary sensors for the car to run. distributor pickup, coolant temp, tps, air temp, and map...nothing else.
-Jay
Lo-Fi Version Time is now: November 29th, 2024 - 4:30 AM
