3 Pages V  < 1 2 3
> 3sgte incoming, GT4
post Nov 19, 2013 - 9:01 PM
Box
Joined Feb 23, '12
From Warrior, AL
Well, just checked and the entire head gasket set is under $60 shipped off Rock Auto. So, just doing that and including fluids it'll be under $100. tongue.gif Might as well do timing, it's only another $40 or so for the timing set. Still well under $200 to do everything yourself and having the head resurfaced.
2001 Miata LS 5-speed
post Nov 22, 2013 - 7:38 PM
DUHCHINKYAZN
Joined Aug 3, '12
From AUS
QUOTE (bsamps4 @ Nov 19, 2013 - 3:58 PM) *
QUOTE (Box @ Nov 18, 2013 - 3:02 PM) *
What about just replacing the head gasket...? That's the most feasible option cost wise. Do it yourself and it won't cost over $100.
What he said. Only it's for sure more than 100 bucks once you add up the fluids, gasket set, timing belt, tensioner, etc...but still. Just fix it. It only takes a couple days (if you're doing it right ie... sending the head to a machine shop to get resurfaced).
Thanks for the replies guys! Im still unsure on what to do atm, but really would like to do a 3s swap smile.gif been reading around the forums and have been tempted by other owners that have done the swap.
@bsamps, just a quick question does the stock 5s tranny bolt to a 3sgte? (Considering that you've done the swap)
I have searched around the forum for this and everyone says yes but some toyota nerd nearby where i live thinks not; so yeah.
It's my car, I do what I want... Don't like it? Buy your own and do it your way.
The best CELI in Western Australia. (Soon to be)
http://www.6gc.net/forums/index.php?showto...=0#entry1009080
^progress thread.
post Nov 22, 2013 - 9:23 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (DUHCHINKYAZN @ Nov 22, 2013 - 7:38 PM) *
Yes, the S54 manual tranny that comes with the 5S will bolt-on with no problems AND should be fine with a 3SGTE as long as you aren't putting down crazy amounts of horsepower or torque.
Has no more Celicas
post Nov 22, 2013 - 9:44 PM
richee3
Joined Jun 29, '08
From Denver
Yes, it will fit. It's done on 9/10 swaps.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 22, 2013 - 10:53 PM
danmumo
Joined Oct 10, '13
From Ontario, Canada
QUOTE (Keiri @ Nov 22, 2013 - 9:23 PM) *
QUOTE (richee3 @ Nov 22, 2013 - 9:44 PM) *
And would you also use the axles from the 5s or...?
post Nov 22, 2013 - 10:55 PM
richee3
Joined Jun 29, '08
From Denver
Yes. Same transmission so it uses the same axles.
1998 Celica GT-
BEAMS Swapped.
post Nov 23, 2013 - 12:14 AM
DUHCHINKYAZN
Joined Aug 3, '12
From AUS
QUOTE (richee3 @ Nov 22, 2013 - 10:55 PM) *
Thanks for info guys!
Looking for someone that can help me put the engine now and maybe have a 3s swapped celica soon!
Of course after reading few other peoples threads for more info and after sourcing a halfcut smile.gif
This post has been edited by DUHCHINKYAZN: Nov 23, 2013 - 12:18 AM
^progress thread.
post Nov 23, 2013 - 8:21 AM
bsamps4
Joined May 16, '10
From Raleigh
You have to get a hybrid clutch setup. Needs to have 5sfe clutch spline with 3sgte pressure plate. Spec makes this clutch as well as other brands. I'm sure there are other guys on here that can chime in with the other clutch companies that make the hybrid kit. I'm just partial to Spec.
post Nov 23, 2013 - 8:50 AM
DUHCHINKYAZN
Joined Aug 3, '12
From AUS
QUOTE (bsamps4 @ Nov 23, 2013 - 8:21 AM) *
Thanks for the info!
How much hp can the 5sfe box hold? Just wondering, not because im going to have a 600hp celica tongue.gif
^progress thread.
post Nov 23, 2013 - 10:02 AM
bsamps4
Joined May 16, '10
From Raleigh
300 at the wheels.
post Mar 2, 2014 - 11:23 AM
DUHCHINKYAZN
Joined Aug 3, '12
From AUS
UPDATEEEEEEEEEEEEE!
Head gasket got fixed, re machined the head and all is running well now. Not much more to say besides some little updates i will post photos on later.
Oh i might be getting a GT4.
sorry for the long lost un updated info.
^progress thread.
post Apr 11, 2015 - 9:56 AM
DUHCHINKYAZN
Joined Aug 3, '12
From AUS
Hey guys been a long time since last post... LOL !
Anyway down to business massive update!
My 6gc currently looking the biz still on stockies hahaha and HG all fixed lol (was fixed a very long time ago)
http://i1029.photobucket.com/albums/y355/r...6551612159.jpeg
and to add i also got a GT Four
http://i1029.photobucket.com/albums/y355/r...0912_161814.jpg
Has Fmic, 3" exhaust, some ok looking wheels and some little goodies in the car. Am living the life...
BUTTTTTTTTT that was very short lived... While out cruising car started getting smokey... got home and checked it out... some internal damage has been done. And later taken to a shop found out cylinder 3 has taken some damage to the piston ring. Rebuild coming on!
SKIP SEVERAL MONTHS
Car is in shop
Parts a rolling through
Parts obtained-
BLOCK FULLY REMACHINED
HEAD FULLY MACHINED
CP PISTONS
SHWAJFAKSMCAK FORGED RODS shotpeened (sorry forgot the german brand)
COMETIC METAL HG
KING RACING Bearings
BC RACING 264 CAMS
TITANIUM VALVE SPRINGS/RETAINERS
HKS ADJ CAM GEARS
ARP HEADSTUDS
ARP MAIN STUDS
Part to be obtained-
GTX 3582R .82
Custom exhaust manifold
Tial 44m ext wastegate W/Screamer
Custom intake manifold with some port and polish hopefully
so far thats what i can remember atm sorry guys its very scrambled. Been busy with many things
Progress atm is engine is nearly finished building, engine bay all nicely cleaned down. deleted aircon/all pipes ripped out. Still thinking to block off the EGR but not main concern atm.
Also slowly figuring out my suspension setup but saving up for some BC's BR coils, had them on my 6gc and they still havent failed me so im heading that path probably.
Thanks for the read!
^progress thread.
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 26th, 2024 - 2:43 AM
