painting over certian interior parts |
Apr 26, 2013 - 1:26 PM |
Enthusiast Joined Apr 26, '13 From round rock tx Currently Offline Reputation: 0 (0%) |
I have seen a lot of celica owners will paint over the plastic around where the air vents are and the center consol, I think it would look really cool black and green, but im wondering how to get started
Apr 26, 2013 - 2:08 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
Its really simple. Get some Krylon Plastic paint. Most walmarts have several colors or more online.
There is no prep work. just pop the vents out, clean and spray. I did like all of the interior parts on my orange car (check profile) Its fairly straight forward. You can spray it with actual "car paint" and clear coat, but thats obviously more expensive, but ill look a little better. Ive had mine done for like a year and its still fine. Obviously it can scratch but if your semi careful with it it will be fine. -------------------- |
Apr 26, 2013 - 2:16 PM |
Wash all of the pieces in warm-hot water with Dawn to pull all the years of oil and grime off. If using Krylon Fusion should be good to go after letting everything dry. Just read the instructions on the can.
Apr 26, 2013 - 2:23 PM |
hate krylon fusion...
get sem products from your local paint supplier.. those are the bomb. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 26, 2013 - 3:05 PM |
Thanks for all the helpful advice! do I have to remove everything while painting or can I leave certain parts in the car? im afraid of breaking the vents or any other plastic
Apr 26, 2013 - 3:55 PM |
If you don't want the interior of your car to smell of paint and be covered in over-spray, then yes.
Apr 26, 2013 - 4:11 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
sand the plastic, clean with acetone (or soap and water), use an adhesion primer, then paint
This post has been edited by garin: Apr 26, 2013 - 4:11 PM -------------------- |
Apr 26, 2013 - 5:00 PM |
If he uses Fusion primer isn't needed. It's specifically formulated to adhere to plastic.
Apr 27, 2013 - 2:21 AM |
Enthusiast Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) |
I did the same last year, sanded a bit, cleaned with degreaser, plastic primer and the spraycan paint.... but I'm not really satisfied with the results, everything is painted half-assed, so I'm going to do the real thing this year, with paint gun...
Apr 29, 2013 - 9:34 AM |
Enthusiast Joined Jul 31, '12 From England Currently Offline Reputation: 0 (0%) |
It's kinda easy to do, I've not long swapped my standard black blastics over to painted white ones although I'll be giving them a going over.
The best thing I can advise is remove EVERYTHING from the plastics too ie vents, heater parts, clock, fog switches etc then give it all a good going over Just take your time you'll be fine |
Lo-Fi Version | Time is now: November 26th, 2024 - 6:39 AM |
