> Hood won't close
post Apr 28, 2013 - 8:13 PM
gts4
Joined Dec 20, '11
From gta
Hood latch won't lock the hood even when dropped from a height. I use a flathead screwdriver to move the cable a bit and get it to lock, but I don't know what's actually going on. Are they easy to replace? Is there a quick fix? Thanks
post Apr 28, 2013 - 8:43 PM
Joebo003
Joined Aug 23, '12
From New jersey
Try some pb blaster on the latch and make sure the spring moves i had the same problem and that was my fix and they r not hard to replace if u had to just 2 bolts and a cable if i remember correctly also make sure the latch isnt bent u may have to bend it a little to get it to catch
This post has been edited by Joebo003: Apr 28, 2013 - 8:45 PM
post Apr 29, 2013 - 9:30 AM
cheela
Joined Feb 2, '07
From Berlin, WI
what I did was undo the latch from the body and just pull it out so the cable tightens and it works again.
Lo-Fi Version Time is now: February 20th, 2025 - 3:38 PM
