2nd gen start, but no idle |
Apr 29, 2013 - 5:53 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
i have a second gen 3sgte. recently replaced a fuel line. the car will start, but dies shortly after. i bought a used iac valve (old one was filled with carbon) also got resistance specs for the maf and it checked out. can anyone lead me into the right direction. maybe some specs for the coil and ignitor? gonna do some more researching at work tomorrow.
Apr 29, 2013 - 7:50 PM |
Unplug the IAC that you bought and see if it will idle.
Apr 30, 2013 - 9:53 AM |
Both iac valves have way to much resistance. Car doesn't stay on when they are unplugged.
Apr 30, 2013 - 11:45 AM |
They are normally in the open position when not powered. So if you disconnect the power source from them the car should idle (but just a bit on the high side).
If disconnecting the IAC valve didn't fix the problem, then thats not your issue. You can bridge B+ and FP in the diagnostic box to make your fuel pump come on and see if that car runs that way. Then pull out your plugs and check for spark. If both of those check out, then you have a loose hose clamp or some other vac leak somewhere after the afm. Any small air leaks will cause a 2nd gen to stall out and not hold idle. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 30, 2013 - 1:14 PM |
ok i'll lok into that
Apr 30, 2013 - 8:46 PM |
stupid vacuum line. thanks art!
Lo-Fi Version | Time is now: November 25th, 2024 - 12:51 PM |
