> Transmission Axle Seal leak
post May 1, 2013 - 9:19 AM
gts4
Joined Dec 20, '11
From gta
Saw a leak - easy to fix?
post May 1, 2013 - 10:01 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (gts4 @ May 1, 2013 - 10:19 AM) *
Easy enough.
Pull the axle on whatever side. Use a seal puller, and put in the new one. I think it took me maybe an hour to do it. Depends on if you plan to re-use your trans fluid, as you will have to drain to do it.
post May 3, 2013 - 9:15 PM
gts4
Joined Dec 20, '11
From gta
Thanks. I'm not too mechanically inclined, and I don't have the workspace. How much do you think a shop should charge for the fix with labour?
QUOTE (rave2n @ May 1, 2013 - 11:01 AM) *
Easy enough.
post May 3, 2013 - 11:37 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
im unsure of how much theyd charge. go ask around and see. Also go and buy the new seal yourself at toyota
エキサイティングカーレーシングチーム!
post May 4, 2013 - 1:21 AM
when i was a noob, i got charged 300 usd.
post May 4, 2013 - 3:54 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
DIY
$10 seal
$50 2 wheel alignment
$0 labour
$10 for fluid
Total $70
Shop with Mad Markups---
$40 seal
$75 4 wheel alignment
$120 2 hour labour
$40 for fluid change
Your grand new total= $300 after tax
post Jan 6, 2014 - 8:32 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
What's the part number for the outer seal? I just noticed mines leaking too so I'm planning on replacing it when I do my soon to do hub conversion. I found a NOK one but not sure if it's the right one. I found this part number but not sure if it's the right one either: 90311-34016
http://www.autopartsnetwork.com/w0133-1838...k/ad8gJUdk2wY4q
post Jan 7, 2014 - 10:12 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
I just did the Cv axle so I know they told me there are three different transmissions and all three different seals
mine was a Timken 223540 (ive got an st204 5s-fe with a 5speed)
http://www.rockauto.com/catalog/moreinfo.p...&cc=1274307
its probably either flat like that one or it has a little cup on the end like this one
I guess this is a good time to ask " where are the ID numbers on the transmission?" I can see some stuff stamped on the top where it mounts to the motor is that it?
I just popped it out and took it up there to match it.
btw they did have the original Timken seal even a O'riely about $8
But this being an "easy" job depends on how easy it is to get that CV axle out, in fact I was under the impression that you Have to take the ball-joint apart,
and that once you separate it the boot is ruined even if the ball joint was good before, and you have to replace it.
Bust a Deal; Face the Wheel.
post Jan 7, 2014 - 11:49 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the 2nd picture is what the seal looks like. Personally i will never use an aftermarket seal. Spend the money, get an OEM seal
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jan 7, 2014 - 1:48 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Smaay @ Jan 7, 2014 - 8:49 AM) *
NOK is oem right?
post Jan 7, 2014 - 3:03 PM
QUOTE (Smaay @ Jan 7, 2014 - 11:49 AM) *
I tried to be careful when installing mine, and inserting the CV. Still, my aftermarket seals both leak, slowly but surely. Does anyone have any idea what the amount of typical fluid loss is? I hope it's not too drastic to necessitate a fill-up, since that means putting the car on four jack stands which is a pain. I never see transmission fluid drips or puddles, but when I had an alignment done the mech showed me two damp trails of grimy fluid.
post Jan 7, 2014 - 3:19 PM
ILoveMySilly97
Joined Mar 8, '12
^If it helps. When I refilled my tranny after I found the leak. I squeezed about 1qt into it before it started to overflow. So my guess would be its holding around 2qts if not less.
post Jan 7, 2014 - 3:31 PM
That does help, thank you.
The only way to refill is to level the car, no? I'd just like to know before I invest in some hardware. I don't have access to a lift.
post Jan 7, 2014 - 7:34 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
I filled mine to 2.7 us quarts based on the info in this thread
http://www.6gc.net/forums/index.php?showtopic=73956
http://www.6gc.net/forums/index.php?showto...2;cv+axle\
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 12th, 2025 - 5:59 AM
