Enthusiast Joined May 3, '13 From VA Currently Offline Reputation: 0 (0%) ![]() |
Hey Folks,
New to the forum - hoping someone has already gone through this before (did a search but couldn't find anything): I've got stock alloy rims on my 96 'vert, want to know what my center cap options are. The brochure showed the ones with the Toyota symbol in the middle, but if you go to hubcaps.com, they don't show that as an option. How interchangeable are the various center caps for this type of wheel? Thanks, Dennis |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
I'm not sure how interchangable they are. but I know there are some with the toyota symbol in the middle and some blank ones. I got a blank one when I bought a rim off someone on here. Might be the difference between pre-facelift(94-95) and facelift (96-99). are you missing one? i can dig up that blank one for you if you need.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
I believe that we have the only caps that fit our rims. I've seen similar caps on Camrys but those are larger. So far as I've ever seen, no other cap will fit.
I believe that we have the only caps that fit our rims. I've seen similar caps on Camrys but those are larger. So far as I've ever seen, no other cap will fit. Thanks folks. I found a part number and put some on order. We'll see what shows up! Yay, center caps arrived - brand spankin' new from Toyota, machined face with the Toyota logo! I know the OEM alloys are not the snazziest rims, but I wanted to go stock and it was a fairly cheap way to go from steel wheels to alloy! If anyone's missing a cap, the part number is 20550. You'll see other numbers out there, but they're wrong - either for the painted face wheel or a different wheel altogether. Cheers, Dennis |
Lo-Fi Version | Time is now: February 20th, 2025 - 11:31 AM |
