ST 7AFE Distributor, Now is not starting |
May 3, 2013 - 2:16 PM |
Enthusiast Joined Feb 18, '09 From Costa Rica Currently Offline Reputation: 4 (100%) |
As the Title said I need the Distributor part number for an AT200 1.8 7AFE.
I finish to rebuild my the engine and when I was about to start didn't received spark, I open it and the Igniter coil had all the copper cables out, so is dead. I planing to buy a new one but I need to confirm the part number. This post has been edited by yagamius: May 7, 2013 - 7:49 AM -------------------- 1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored |
May 3, 2013 - 8:02 PM |
Enthusiast Joined Sep 25, '11 From GreatSmokyMtns NC Currently Offline Reputation: 3 (100%) |
As far as I can tell there are a few numbers for the 7afe. Not sure about the difference between them. 19050-74010... 19050-74020... 19050-74030... 19050-74040
May 4, 2013 - 4:35 PM |
Enthusiast Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
As the Title said I need the Distributor part number for an AT200 1.8 7AFE. I finish to rebuild my the engine and when I was about to start didn't received spark, I open it and the Igniter coil had all the copper cables out, so is dead. I planing to buy a new one but I need to confirm the part number. Hello, You best check on toyodiy.com. There will be the correct part number. Otherwise call your local Toyota dealer for the number. You can even ask them for discounts, most of the times they'll do. -------------------- |
May 7, 2013 - 7:48 AM |
I bought a new distributor and the car still not starting. there is something electric and is not going to the distributor.
what I notice is that the Check Engine Light is not on when I set the key to ignition tried with the scanner and is not getting signal either I'm hopping is not the ECU because I removed the cluster fuse and the engine light goes on but blinking and the temp goes high with the car Off so there is something electric going on. any Idea ? -------------------- 1994 ST Celica --> no swap --> 7A rebuild
Lo-Fi Version | Time is now: December 1st, 2024 - 11:31 PM |
