Enthusiast Joined Oct 21, '03 From Upstate New York Currently Offline Reputation: 0 (0%) ![]() |
Aight, I have been reading a little, but between college and work, I haven't had enough time to read everything, so I don't know if this is a repost... BUT I was wondering if a 3sgte from a USDM mr2 (if a 3sgte motor available in it) is the same thing as a 3sgte from a JDM celica gt4... my thinking is that a 3sgte is a 3sgte is a 3sgte, but with the mr2 being a mid-engine it could change the engine around. OH and I am talking about a 3 gen. 3sgte from a 94 on gt4...
Thanks for the help |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) ![]() |
You answered your own questions!
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) ![]() |
He's right. It basically all depends on the power!
-------------------- 95 Toyota Celica GT
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) ![]() |
For starters... there were no USDM MR2's that came with a 3rd gen out of the factory...
There are quite a number of differences b/w the setup of the MR2 3s with that of the GT4. The motor itself is practically the same... but certain things are different... |
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) ![]() |
also, swaps have been made from both cars, so they are both feasable, it all just depends on your resources I guess
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
both motors will work, however there are differences. the USDM mr2 always came with the 2nd gen 3sgte. however this motor is still different than the USDM Alltrac Celica's 3sgte. the JDM MR2 3sgte motor (making 245BHP) still has differences from the jdm GT-4 motor.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
this is directly pulled off the newbie forum on the MR2 owners club messageboard. these are the differences between the USDM gen2 MR2 motor, and the gen3 MR2 motor. THIS HAS NOTHING TO DO WITH ANY GT-4 MOTORS.
you'll also find that it will be much easier to find parts for the MR2 version because it is USDM, so parts will be more readily availalbe and most likely cheaper over here
Please keep in mind that it won't necessarily be that difficult to get parts for a gen 3 motor. Some parts from the gen 2 motor can be used... others can be found from other cars.
For example, the thermostat for a gen 3 is the exact same thing as the one they use in a Landcruiser... And to be honest... how often will you have to replace parts like that? ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) ![]() |
ummm, ct20b, ahhh <---- drool
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
id personally rather get a TD-06 kit than a CT-20b, both are very sweet though.
I didnt know stock boost on an MR2T was 10psi, its 8.5 stock on the alltrac's so what are the stock MR2T's pushing? (USDM)
stock MR2 ranges from 8.6-10.0 PSI under normal conditions. ive also heard lots of people with just filter and exhaust mods, hit the fuel cut from boost creep...
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
My question is what about the parts that are replaced often? e.g. belts, hoses, oil filter, etc....If I go with a gen 3 swap, will I have to import these things? If so, are they readily available and how long does it take? Also, assuming that I went with a gen 2, would I have the same problems if I went with a jdm rather than usdm? -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
keep inmind that the US had the 2nd Gen Alltrac, so if you get a 2nd Gen 3sgte, parts are all availabe in the US. If you get an ST205 3sgte then I do believe your going to have to look else where for parts.
Oil filter.. same Timing belt... off by one tooth, but can still be used. ToyotaWorld can get the gen 3 belt tho. Hoses... not even an issue... |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) ![]() |
If you get a 2ng gen, ALL parts will be available in the US. A very big deciding factor for me on which gen to get. Its just alot less hassel and you will always know that you can get a part without searching the world twice over.
![]() Enthusiast ![]() ![]() Joined Jan 8, '03 From Miami, FL Currently Offline Reputation: 0 (0%) ![]() |
i have mr2 engine and tranny in my baby.... look at sig, and/or profile... fits pretty well. works pretty, well. stock boost is 10psi, turned it up to 18, then overboosted and cracked a piston
... whatd you have your FCD set at?? rule of thumb on the MR2 boards is not to push it past 14-15PSI with a 17PSI fuel cut untill doing some upgrades to the motor... theres other ways to make big HP on those motors rather than just cranking up the boost.
I think that if he was running water injection, he would've been alright... but 18 constantly is a lot! I agree... 14 to 15 is all the motor can handle with the crappy piss water gas we have here in the states... with a stock 3S... This post has been edited by kuya1284: Jan 27, 2004 - 2:45 AM |
Lo-Fi Version | Time is now: February 17th, 2025 - 3:20 PM |
