> How to: axle spacer on 3sgte swap, using hybrid axles on e153 tranny
post May 9, 2013 - 9:50 AM
diegohiga
Joined May 4, '09
From coral springs florida US
I realized that there is no much info about this spacer and I thought this might be helpfull for some people using e153 tranny on their swap.
I used lsd mr2 inners and st185 outters
If you bolt the mr2 inners to the tranny and st185 to the hub you will have a gap of about 1/2 inches in the middle of the 2 axles.
The spacerr was made out of the mr2 axle. This is the piece you remove from the mr2 axle to make the hybrid one.
You need to cut this section which measures exactly 1/2 inch
Then take the spacer to a machine shop to make the surface flat and flush
Mount it to the st185 axle
And get longer bolts and you are ready to install it
post May 9, 2013 - 11:37 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
excellent write up.
I find it really interesting that im using an E153 with MR2 LSD inners as ST185 outters and no spacer. i have had no problems at all.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 9, 2013 - 12:31 PM
diegohiga
Joined May 4, '09
QUOTE (Smaay @ May 9, 2013 - 12:37 PM) *
excellent write up.
Thanks and yes it can be installed without the spacer but the axle gets streched about 1/2 inch and the cage from the st185 ends up coming out and breaking it (sometimes) And if you lower the car I believe it stretches more and the cage breaks faster, which happened to me after 1 month after the swap.
post Jun 22, 2013 - 2:41 PM
TwistedCeli94
Joined Nov 15, '08
From Raleigh NC
What did you use to cut the hard steel? I took the axle to a machine shop and he couldn't cut it
post Jun 22, 2013 - 4:48 PM
diegohiga
Joined May 4, '09
QUOTE (TwistedCeli94 @ Jun 22, 2013 - 3:41 PM) *
I used a grinder, used a wheel for metal. It takes some time to do it but it cuts it. Then take it to the machine shop to leave the surface even
post Jun 23, 2013 - 11:46 AM
TwistedCeli94
Joined Nov 15, '08
From Raleigh NC
K great thanks....also maybe this is a stupid question but if you need the mr2 inner...how are you cutting it up? I thought I used the left over parts to make it the 1/2 inch spacer
post Sep 11, 2013 - 10:44 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
this isn't stickied?? the other 13 page stickied thread just seems full of lots of talk.
This post has been edited by BonzaiCelica: Sep 11, 2013 - 10:44 PM
post Sep 13, 2013 - 2:07 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Whats the new bolt size?
Lo-Fi Version Time is now: November 28th, 2024 - 12:08 PM
