Sunroof and door panel repair question |
May 21, 2013 - 6:08 PM |
Enthusiast Joined Mar 15, '11 From Belfry, kentucky Currently Offline Reputation: 5 (100%) |
My sunroof quit working right after a friend tried to open the sunroof with the shade closed. Now it will not slide open at all, and will open up only with the slide button. I got another sunroof motor at an pull-a-part the other day, I was wanting to know how do i adjust the motor to make sure everything is lined up right when i swap out motors.
Also picked up a couple of door panels but they have cracks on the boards on the backside, i was wondering what's the best way to fix those. |
May 28, 2013 - 12:50 PM |
i wish i could understand but i dont understand which pieces are broken. pics would help
May 28, 2013 - 1:35 PM |
First thanks for the reply, did not thank any one would reply,lol. On the door panels, the wooden board on the back of the door panel is what is broken. One of my door panels the arm rest has a good crack in it, and some other places has problems. I will try to take some pics
May 28, 2013 - 2:32 PM |
Its been awhile since I've looked at door panels, but you might be able to push the cracks back into place then reinforce from the inside using fiberglass?
May 28, 2013 - 3:18 PM |
Yeah i can push the cracks back together, i just did not know what to use to reinforce the area.
May 29, 2013 - 11:33 PM |
Enthusiast Joined May 25, '13 From Charlotte, NC Currently Offline Reputation: 0 (0%) |
Absolutely use fiber glass. It'll adhere just fine to the back of the door panels and give a strong reinforcement. I went ahead and reinforced my driver's side door panel with fiberglass (right when I noticed it was weakening) and have never had an issue since using the fiberglass. I never did get around to the passenger side and the passenger side is already busted. The only crappy thing is that you'll never get the vinyl cover on the door panel to look the same again. It'll be as strong as can be though! If it's already busted, be sure to do the entire arm rest portion of the door panel.
May 30, 2013 - 6:17 AM |
Thanks, i will give that a try. Can you order a new sunroof motor or is the only ones you get is from the junkyards?
Lo-Fi Version | Time is now: November 30th, 2024 - 4:47 AM |
