FS Arc Audio KS 300.2 Amp, Please close |
May 22, 2013 - 6:22 PM |
Enthusiast Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) |
Killer amp sold my speakers though so no longer need the amp. Specs below. MSRP 449 looking for 200 shipped.
2 Channels @ 4 ohms 180 Watts 2 Channels @ 2 ohms 350 Watts 1 Channel @ 4 ohms (bridged) 700 Watts Frequency Response 5Hz - 50kHz Crossover Range 55Hz - 5.5kHz Variable Bass Boost +15dB @ 45Hz S/N Ratio 98dB Input Sensitivity (Low) 220mA - 3.5V Max current draw 70A @ 751 Watts 20% THD Idle Current 1.14 Amps Fuse 3 x 30 Amps Dimensions 11.25" (L) x 8.0" (W) X 2.375 (H) The KS amplifiers are a totally "out of the box" rethink of what an amplifier can be. By taking a proven but underutilized Pro Audio amplifier class and bringing it up to date with modern components we can achieve uncompromising sound quality in a compact chassis that makes installation in even the most challenging cars and trucks a breeze. Switching to a higher class. Class G and Class G/H amplifiers offer the best of all possible characteristics. Power output, distortion, efficiency, heat, noise, size are all class leading specs with this design. Why does this class or amplifier perform so well? It's built for music not test tones or noise. Class G/H works with the dynamics of music not against then. When an amplifier is playing music even at full volume, due to its dynamic nature, it is really only working above 1/2 power about 10% of the time. You only need full power during the very loud passages like the impact of a drum or the pluck of a bass string. The rest to the time your 700 watt amp is making less then 350 watts. That's where the KS amp's Class G/H comes in. It's like having 2 amps in one. A 400 watt amp that can be a lot smaller and makes a lot less heat that in a fraction of a second becomes an 800 watt monster. The trick of making this work is striking a balance between switching this high power section on and off. It takes the years of experience Nikola Engineering has to achieve this delicate balance. This post has been edited by chucho: Sep 12, 2013 - 2:16 PM |
May 28, 2013 - 6:11 AM |
Bump
Jun 11, 2013 - 3:36 PM |
Anyone in need of a killer amp? PM me
Jun 19, 2013 - 12:10 AM |
Enthusiast Joined Apr 24, '13 From Tomball, TX Currently Offline Reputation: 3 (100%) |
Got a picture of it? Of the top and the connections, knobs, ect.?
-------------------- "As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
Jun 19, 2013 - 7:38 PM |
Jun 20, 2013 - 10:38 AM |
Jul 3, 2013 - 1:21 PM |
bump
Jul 17, 2013 - 8:26 PM |
bump
Aug 16, 2013 - 5:34 PM |
Any reasonable offers?
Sep 12, 2013 - 8:22 AM |
Put up on Ebay
Sep 12, 2013 - 1:30 PM |
Enthusiast Joined Sep 13, '10 From Austin, tx Currently Offline Reputation: 3 (100%) |
Sep 12, 2013 - 2:01 PM |
Put up on Ebay so this cannot drive all 5 channels at once, correct? No, it's 2 channels at once, or 1 channel bridged (with higher power). It's a 2-channel amp -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Sep 14, 2013 - 9:37 AM |
Depending on the wattage and if you put bigger fuses in it you could technically run more than two.
Lo-Fi Version | Time is now: December 1st, 2024 - 8:54 PM |
