> Air Filter which is better?
post May 23, 2013 - 7:48 AM
alex_k
Joined May 23, '13
From Cyprus,Limassol
My car have the stadard air filter...Its better to change it and put a mushroom air filter? Which one do you suggest me? I have listen very good opinions about the weapon-r dragon filter?
トヨタ
"Some age, others mature"
post May 23, 2013 - 12:50 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Injen or weaponR. Up to you.
post May 23, 2013 - 1:02 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Do a google search, you should find a lot of review not only on this site but on the other automotive forums as well.
God made man....
Everything else...
Made in China
post May 23, 2013 - 1:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
If you're not going to do a true cold air intake you're better of with using a K&N panel filter.
2001 Miata LS 5-speed
post May 23, 2013 - 1:59 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Box @ May 23, 2013 - 11:57 AM) *
+1 I would have done this if my hose isnt cracked
God made man....
Everything else...
Made in China
post May 23, 2013 - 2:09 PM
alex_k
Joined May 23, '13
Yes i think about K&N panel filter but i will not have any change with the sound of the engine right?
トヨタ
post May 23, 2013 - 3:23 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (alex_k @ May 23, 2013 - 2:09 PM) *
No. If you want sound go with a true cold air that puts the filter into the fender. The short ram intakes that have the filter exposed in the engine bay actually provide no gain, if not hurt performance.
post May 23, 2013 - 3:38 PM
alex_k
Joined May 23, '13
QUOTE (Box @ May 23, 2013 - 4:23 PM) *
okay i will try to find a way to bring the filter in the front of the car or i will make a handmade box and put it inside..
トヨタ
post May 23, 2013 - 4:10 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (Box @ May 23, 2013 - 11:23 PM) *
What is the reasoning behind the sound change and how would it actually sound?
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post May 23, 2013 - 6:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
Some people like to hear the air coming into the engine. I do personally since I shift by sound most of the time.
post May 24, 2013 - 3:40 AM
ILoveMySilly97
Joined Mar 8, '12
A short ram roars while the cold air purrs. I like the roar but some like the purr since it sounds like a whine(aka turbo). Lol.
ILoveMySilly97
Joined Mar 8, '12
post May 24, 2013 - 3:52 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If you get a cold air and its a two piece, put on a bypass filter in between the two pipes. Nothing sucks worse than sucking up water.
post May 24, 2013 - 3:56 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (soulshadow @ May 24, 2013 - 3:52 AM) *
If the filter is located into the fender and not the bottom of the car shouldn't have a problem with that. If water reaches the upper fender I think sucking water is the least of your concerns at the moment. tongue.gif
post May 24, 2013 - 9:35 AM
alex_k
Joined May 23, '13
QUOTE (Box @ May 24, 2013 - 3:56 AM) *
if i put the new filter in the same position where the panel filter box was its okay do you think?
トヨタ
post May 24, 2013 - 11:11 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I drove 2 years ago with water half way up my 17" wheels from a massive flood. My exhausts went bloop bloop bloop. After that I took off the other section of the intake and made it a short ram.
post May 25, 2013 - 1:22 AM
alex_k
Joined May 23, '13
QUOTE (soulshadow @ May 25, 2013 - 12:11 AM) *
Wow :-) the good here i live in Cyprus we never have too much rain, and usually when its raining i never take the celica out tongue.gif
トヨタ
post May 25, 2013 - 2:09 AM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
I found that Apexi air filters are really good as well . Up to par if not better than K&N. unfortunately they are expensive but well worth the costs in my opinion. Been running them for 5 years now with no problem what so ever.
post May 25, 2013 - 3:37 AM
Syaoran
Joined Jan 4, '12
From US
I saw a filter comparison somewhere where a couple of filters were tested against each other in a filtering and airflow test. Mushroom filters came out best flowing because the ones they used were designed with a velocity stack integrated into them which helps flow massively.
Cone filters the K&N was the best in terms of filtering but required maintenance (cleaning and re-oiling) to keep its filtering ability up its best. AEM Dryflow filtered less but requires less maintenance (just clean with water) and flowed a little better too iirc.
Apexi filter was the best, I think it filtered better than the K&N and flowed better too, but was really more expensive than any other filter. I think the other filter they used was the HKS mushroom.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post May 29, 2013 - 10:26 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Completely false. They tested this and it makes no difference where the filter is, not a noticeable one anyway. What really matters is the intake piping being a direct line into the throttlebody instead of having sections of dead and turbulent air due to stock baffling and "water protection" boxes.
Ideally, the best setup is the stock air box with a high flow air filter and intake piping off of it into the throttlebody. Our Celica's take air from the front bumper and route it through the driver fender into a intake hole up to the air filter. I have my filter positioned right behind that intake hole/plastic air route piping and it does fine.
Watch this:
http://youtu.be/gCi2yo4UqPI
QUOTE (Syaoran @ May 25, 2013 - 4:37 AM) *
For selecting a correct filter, this is right on for air flow. Realistically, the K&N, AEM, Injen, Weapon R, Spectre filters are all the same when it comes to oiled filters. So don't waste your money on the high end ones. Mushroom filters are most likely to allow dirt through, and you might as well use a stocking, and Dry Flow's seem to work well...
Realistically though, you're not going to notice that much of a difference between them. So pick one you think looks and sounds cool and go with it.
This post has been edited by RabidTRD: May 29, 2013 - 10:46 AM
Lo-Fi Version Time is now: November 30th, 2024 - 11:46 PM
