Enthusiast ![]() ![]() Joined Jun 26, '12 From Seattle, WA Currently Offline Reputation: 1 (100%) ![]() |
Hey all. Looking to reduce the periods of understeer that my car goes through when taking turns tightly, and sometimes not even that tightly at all. Mosty in wet weather, but where I live thats most the time anyway. I have a farely stock 95 gt, only mods in question currently are Megan springs and stag struts on it.
I did a tad bit of searching the forums and found some info, and I was hoping to get some clarification and maybe some advice. Will these modifications/addtions help me in this quest? lower front end Front strut tower bar F&R sway bar Is there anything else that can help? Will a strut tower bar/thicker sway bars really help? This post has been edited by snagmor: May 29, 2013 - 2:01 AM |
Make it RWD.
![]() This post has been edited by Box: May 29, 2013 - 4:17 AM -------------------- 2001 Miata LS 5-speed
Enthusiast Joined Apr 25, '10 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
At the moment my car has rear bar disconnected. Noticed slightly better turn in with no added body roll. Thicker front bar on your car will help with understeer.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) ![]() |
First of all... what tyres are you running? When I went from 15 to 16 inch rims I traded up from really cheap crud to UHP tyres (Michelin Pilot Sport 3) and they are AMAZING!!! XD (UHP = Ultra High Performance, but standard HP tyres are better value for money) -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) ![]() |
Just to be clear, do we know what understeer really is? Understeer is sliding by the front wheels. If the wheels aren't sliding you're not understeering, you're just not turning the wheel hard and fast enough.
In your case in what you described, it seems unlikely to me that you're actually understeering since you're not really pushing the car near its limits. If you actually are understeering in those conditions, your tires probably really really suck for the given conditions. No other mod you can do is going to help you more than a good set of tires for the conditions. In the wet with garbage tires, real understeer you should be nearly wrecking, because once ****ty tires break lose it would be hard for them to find grip to recover, especially going speeds into corners that would induce understeer. This post has been edited by czwalga: May 29, 2013 - 6:40 AM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) ![]() |
I always get oversteer in my 94 GT, its the rear tires I struggle to keep from going out sideways. How much throttle are you applying when you experience understeer? Its easy to start sliding if you suddenly cut the wheel to the lock or nail the throttle to the floorboard; if your using proper technique(taking the correct line through a corner and knowing when to brake/accelerate) you will find the celica has very balanced handling
This post has been edited by Special_Edy: May 29, 2013 - 3:10 PM |
Enthusiast ![]() Joined Apr 5, '10 From conneticut Currently Offline Reputation: 1 (100%) ![]() |
I know the celica chassis is a completly different animal than my 7th gen civic, but what we can do for the whole oversteer/understeer issue is change the sway bars.
Big front/small rear= Understeer Small front/big rear= Oversteer Just a thought |
I have a decent set of tires on mine, one of the ones out of the potenza series. TRD front coilovers, Hotbits rear coilovers, 3pt front strut bar, and a 2pt rear strut bar, and a harness bar inside too. Just on stock sway bars and upgraded rear end links. My car doesn't really under steer or over steer that much with this setup. If I'm hitting a corner hard and I cut it a little bit harder, the car will start to whip the back end out. You would think it would under steer instead of over because of it being fwd, but if you let off the gas as you cut it harder you'll gain more traction in the front. From my understanding it's because the car dips forward when you let off the gas and that causes the weight to shift forward and all this other stuff. You can look it up if you really want to understand cornering and all that stuff.
Really, it's about how you drive your car though. If you don't know how to take corners, then that's your first problem. You don't just cut the wheel really f*cking hard to one side or the other and you don't just floor it either. You need to learn where to brake, where to give it gas, when to not give it gas, but you also need to know how to carve a corner. But like steve was saying, you need good tires to be able to corner well. |
I find it best to not use any throttle while taking a hard corner, as doing so would just take away grip from the front tires. That being said I haven't really had any issues with under-steering. I also can't help but notice everyone else has the GT, so maybe the ST having a lighter drive-train helps to a degree. The Celica is definitely the best handling FWD car I've driven.
FWD, basically should be brake, gas and left foot braking. AWD, Lift/turn/brake. Rwd, Brake, turn, GAS!!!! Counter steer haha. Really all this varies depending on surface though. If you have great traction they are all similar.
This post has been edited by czwalga: May 29, 2013 - 12:39 PM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) ![]() |
This thread reminds me how bad I want to take the Celica and Z to a track day so I can get some seat time and practice driving both more properly.
![]() -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Rear strut bar has the biggest effect, in my opinion.
'93 MX-5 LE |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) ![]() |
I believe stiffening the rear would help reduce understeer significantly.
Sway bars, and endlinks would probably help the most. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) ![]() |
At the moment my car has rear bar disconnected. Noticed slightly better turn in with no added body roll. Thicker front bar on your car will help with understeer. What? Stiffening the front end increases understeer. Understeer is when you can see whats about to kill you. Oversteer is when you can't see it because you're going backwards. Stiffer rear end results in less understeer from my test results. I've played with bars, bushings, suspension settings, and tires. Even with grippy tires, the front tries to go straight under lots of pressure. How I remedied my issue was by putting the ST205 rear strut bar (top mount) in, energy suspension rear sway bar urethane bushings, MOOG sway bar links in the rear, and coilovers with a heavy spring rate and a mid setting (18 out of 32) for dampening. My rear also sits slightly higher than my front end. Car actually oversteers into corners at high speeds now with my winter tires on lol. No hand brake needed. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Snap over-steer is my favourite, then you just spin like a top until exploding into a small ball of flames. Of course you only get that kind of fun with MR vehicles, shame.
![]() This post has been edited by Box: May 30, 2013 - 1:45 AM -------------------- 2001 Miata LS 5-speed
At the moment my car has rear bar disconnected. Noticed slightly better turn in with no added body roll. Thicker front bar on your car will help with understeer. What? Stiffening the front end increases understeer. Understeer is when you can see whats about to kill you. Oversteer is when you can't see it because you're going backwards. Stiffer rear end results in less understeer from my test results. I've played with bars, bushings, suspension settings, and tires. Even with grippy tires, the front tries to go straight under lots of pressure. How I remedied my issue was by putting the ST205 rear strut bar (top mount) in, energy suspension rear sway bar urethane bushings, MOOG sway bar links in the rear, and coilovers with a heavy spring rate and a mid setting (18 out of 32) for dampening. My rear also sits slightly higher than my front end. Car actually oversteers into corners at high speeds now with my winter tires on lol. No hand brake needed. I have driven over the same hill, 5 to 6 min of driving, 6 days a week for 5 years. Hill has a lot of tight and off camber corners. So im pretty confident in how the car feels. So much so that I have the Moog endlinks and poly sway bar bushes going in next week and im not overly excited about it. I'll see. |
This post has been edited by SwissFerdi: May 31, 2013 - 9:18 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
front lsd.
mr2 turbo gearbox? whatever, you need a front lsd to fix throttle-on understeer however you can compensate for an understeering car by the way you drive, it's called weight transfer. -------------------- Mike W
![]() Enthusiast ![]() Joined Mar 19, '11 From Utah USA Currently Offline Reputation: 0 (0%) ![]() |
Higher tire pressure in the front tires makes a big difference, and like a couple people have mentioned rear sway bar, higher rear spring rates, and just stiffen up the rear as much as you can. I find my car handles the best when the rear can slide. Proper entry speed is also a huge factor. If you are going faster than the car can handle, just hold on because it's going where it wants to.
-------------------- 90' Toyota Celica GT (sold)
99' Toyota Celica GT |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) ![]() |
Snap over-steer is my favourite, then you just spin like a top until exploding into a small ball of flames. Of course you only get that kind of fun with MR vehicles, shame. ![]() That happened to me twice on a steep downhill curve ![]() -------------------- God made man....
Everything else... Made in China ![]() |
Lo-Fi Version | Time is now: February 19th, 2025 - 11:15 PM |
