2 Pages V  < 1 2
> The pink panther
post Jun 7, 2013 - 9:54 PM
ToTheTop
Joined Mar 31, '13
From Georgia
QUOTE (Box @ Jun 7, 2013 - 10:39 PM) *
The grind when downshifting into third is a common problem, due to the synchronizer. Some people have luck using Synchromesh.
Thanks for the info wink.gif would u happen to know where in the world I can order damn power steering lines? And I have one ac line but I'm not sure if u need two or not. Also wat can I do to make the engine chrome/Matt black like its supposed to look
Looking to build up my 94 3sgte
post Jun 7, 2013 - 10:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
I would check eBay and Rock Auto for power steering lines. Worst case scenario would have to get from the dealer. Then again I'm sure you could fabricate something.
This post has been edited by Box: Jun 7, 2013 - 10:11 PM
2001 Miata LS 5-speed
post Jun 7, 2013 - 11:18 PM
ToTheTop
Joined Mar 31, '13
From Georgia
I was actually wondering if the mr2 lines would work? And which engine do I have is it the st185rc model?
This post has been edited by ToTheTop: Jun 8, 2013 - 2:52 PM
post Aug 21, 2014 - 9:08 PM
ToTheTop
Joined Mar 31, '13
From Georgia
Updateeee
So I've been busy doing a 3rd gen swap for the last year almost.
I need a shop in georgia to finish it, the shop tht had it did a terrible job and
Now I'm 3 grand out and I need help! Anybody know anybody 🙏🙏
post Aug 22, 2014 - 10:00 AM
whats pending to do the swap. are you afraid to do it yourself? be more specific. wiring, engine mount, exhaust?
post Aug 22, 2014 - 10:35 AM
JasonTX
Joined Mar 1, '10
From TX
if your not opposed to turning your own wrench. theres a wealth on info here on the board on just about every aspect of the swap. also a bunch of helpful people with all the toyota tech refrence materials.
just ask
This post has been edited by JasonTX: Aug 22, 2014 - 10:35 AM
JN 3:16
post Aug 23, 2014 - 7:19 AM
ToTheTop
Joined Mar 31, '13
From Georgia
QUOTE (njccmd2002 @ Aug 22, 2014 - 10:00 AM) *
I actually work on the road 24:7 so no time to swap it myself, the motor is put in but they wired it wrong an it's running rough
I need the wiring fixed and the 3rd gen top mount put on as they put the second gen
Top mount on the motor.. Also I don't have all the tools to finish it myself
This post has been edited by ToTheTop: Aug 23, 2014 - 7:22 AM
post Aug 23, 2014 - 8:13 AM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (ToTheTop @ Aug 23, 2014 - 7:19 AM) *
ah yeah i know all about traveling for work and trying to balance the rest of your life. you might get in touch with tweaked performance or wiregap and send em your harness i think its only a few hundred bucks and they send it back !00% plug and play. that being said it only a couple of wires you need to move around on the engine harness for the 3rd gen. i believe its a sticky.
JN 3:16
post Aug 23, 2014 - 11:49 AM
ToTheTop
Joined Mar 31, '13
From Georgia
QUOTE (JasonTX @ Aug 23, 2014 - 8:13 AM) *
The only thing is I don't know if they messed the other one up to bad
And like I said I got no time to do it myself
post Aug 23, 2014 - 11:22 PM
JasonTX
Joined Mar 1, '10
From TX
QUOTE (ToTheTop @ Aug 23, 2014 - 12:49 PM) *
wont really matter you can send em a hacked up harness with stuff missing and thay can replace missing connectors and put it back together. however if you need another fresh harness i have one with everything but the fusebox connection
JN 3:16
post Aug 24, 2014 - 12:59 PM
ToTheTop
Joined Mar 31, '13
From Georgia
I just need someone to finish the swap, the motor is in the car running, just need a couple things fixed up.
Anybody near atlanta that could finish it?
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 17th, 2025 - 8:01 AM
