Working OBD2 on JDM ecu, All you guys with obd2 based engine swaps! |
Jun 3, 2013 - 4:42 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
No, that was just me showing features of the app from my living room
Jun 5, 2013 - 1:39 PM |
Gotta figure out a different plan. I can run Torque Pro on my Kindle Fire but I can't get it directly from the Amazon App Store. Most guys that run it on their Kindles bought it on their Android phones then emailed it to themselves and opened it on the Kindle. The second obstacle is that the Fire is not equipped with Bluetooth. I considered getting an ELM327 to USB, then USB to micro USB adapter. Could work as long as I find an app to work with the signal being plugged in, and I forgot to check to see if micro USB Bluetooth adapters are available. More research when I get home...
Jun 5, 2013 - 5:05 PM |
Gotta figure out a different plan. I can run Torque Pro on my Kindle Fire but I can't get it directly from the Amazon App Store. Most guys that run it on their Kindles bought it on their Android phones then emailed it to themselves and opened it on the Kindle. The second obstacle is that the Fire is not equipped with Bluetooth. I considered getting an ELM327 to USB, then USB to micro USB adapter. Could work as long as I find an app to work with the signal being plugged in, and I forgot to check to see if micro USB Bluetooth adapters are available. More research when I get home... Don't forget, need to charge Tablet as well maybe -------------------- |
Jun 7, 2013 - 9:26 AM |
I hate to burst your bubble, but this isn't OBDII at all. Not even partially.
You're just monitoring the ECU inputs/outputs. You can do this with my 86 Cressida, or any car with an ECU. JDM ECUs are OBDI. Even a brand new 2013 car is still OBDI. OBDII is a completely different diagnostic system than OBDI. They're not compatible, and not translatable. OBDII is governed by US law with specific requirements that are different from OBDI. The codes are different, what the ECU looks for is different, the outputs are different, ect. You will never be able to hook up an OBDII code reader to an OBDI ECU and have it work. Plain and simple. This post has been edited by alltracman78: Jun 7, 2013 - 11:07 AM -------------------- |
Jun 7, 2013 - 11:06 AM |
Just to clarify; I'm not trying to be a jerk, it's a pretty cool idea and it's great to be able to see what's going on.
I wanted to clear up the obvious confusion about OBDII. -------------------- |
Jun 7, 2013 - 8:13 PM |
Just to clarify; I'm not trying to be a jerk, it's a pretty cool idea and it's great to be able to see what's going on. I wanted to clear up the obvious confusion about OBDII. I thought I made that clear in the opening post about this not enabling you to pass emmissions or whatever. But thanks for the clarification! -------------------- |
Jun 9, 2013 - 7:44 AM |
It's not just not passing emissions, it's not OBDII at all.
Jun 10, 2013 - 9:35 PM |
Enthusiast Joined Aug 22, '12 From OC (Garden Grove) Currently Offline Reputation: 0 (0%) |
Not trying to be apart of this debate.... but i always thought and have read somewhere that 1996 obd-ii was mandate in us.. in europe they switch over to obd-ii in 1999 but it uses a different protocol that why it was called EOBD2... in 1998 some company in japan switch over to over obd-II... all different foreign region have there own set of protocol they dont U.S. standrads. So Japan JDM was just know as JOBD.
JOBD is a version of OBD-II for vehicles sold in Japan. They all have different codes... |
Jan 9, 2014 - 10:58 PM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
i tried this with my 3d ge 3sge car off but igution on, no luck. doesnt wanna connect to ecu.
Apr 19, 2016 - 7:44 AM |
Enthusiast Joined Dec 17, '06 From Italia, Bari Currently Offline Reputation: 0 (0%) |
hi, I swapperd the beams red top in my celica, there is no the OBDII port, you know how to connect it?
Apr 19, 2016 - 10:02 AM |
You need to wire one in.
Apr 19, 2016 - 10:21 AM |
how to wire one in?
Lo-Fi Version | Time is now: November 30th, 2024 - 6:02 AM |
