obd 2 wiring and ecu obd 1 car, i need help |
Jun 6, 2013 - 11:35 PM |
Enthusiast Joined Feb 21, '13 From saskatoon Currently Offline Reputation: 0 (0%) |
can i use and obd 2 engine, full wiring harness and ecu in an obd 1 car? i have no fuel and no spark has anyone else experienced this problem? what do i need to change or check? i swapped engine and wiring harness and ecu from a 1998 celica into my 1994 celica it turns over and spins but no spark or fuel checked every fuse in the car. thanks.
Jun 7, 2013 - 11:26 AM |
Most likely the wiring to the chassis is different. All it would take is one or two for it to not start.
You'll also probably get a CEL if you do get it running, because the chassis isn't set up for OBDII. You should be able to modify it so it will work though. -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 5:38 PM |
