Enthusiast ![]() Joined Nov 20, '02 Currently Offline Reputation: 1 (100%) ![]() |
The indiglo gauges were installed a month ago in the Celica. I got these gauges from Speedhut. At first the RPM needle was getting stuck at idle and the speedometer needle was getting stuck at 0-10mph. I still have the same problem with the RPM needle. At idle the needle drops below 500 RPMs, which I know that is not accurate. Also, I've noticed that the speedometer needle is getting worst. When I speed up, the needle jumps and stops jumps and stops until I reach the speed that I'm at. On the highway the needle bearly passes 65 mph when I know I'm going much faster than that (about 75-80). When I slow down its the same thing, drops and stops, drops and stops until I reach the speed or I come to a complete stop. Now I'm worried that this might happen to the gas gauge.
My questions are: - Can it get worst, to the point where the needles will not function anymore? - How can I fix this problem? I will appreciate any help you guys can give me. Thank you! |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
I installed my gauges and I was having similar problems. My speedometer wouldn't go above 20 mph, so I first took out the gauge cluster and took that apart. I then pulled the little needle covers up a little bit(I kinda pressed mine down hard when I put them back on the first time I installed my gauges, and I inserted some more thin 3M double sided tape in between the gauge cluster and the indiglo gauges. I put it all back together, and now it works just fine.
Out of curiosity, did you take off your needles completely when you installed your gauges? -------------------- New Toyota project coming soon...
Yep double sided tape in the way to go. I had the same problem.
Actually a shop told me that the needles will break if they were removed. So I had a shop install them. They did not take off the needles. So this is a pretty easy fix? I'm just worried of breaking the needles. Could someone give me instructions on how to take the whole thing apart? Thanks for the help!
![]() Enthusiast ![]() ![]() Joined Sep 4, '02 From South Carolina Currently Offline Reputation: 0 (0%) ![]() |
http://www.6gc.net/index.php/action/how-to..._article/itu/10 for pictures
http://www.6gc.net/index.php/action/how-to...o_article/itu/9 for installing I screwed up on putting mine on...a little piece of plastic on the front side of the gauges got turned up so I had to peal some off, so now there is a shiny spot around my rpm needle....so thats ruined. |
Thanks for the instructions. Are you going to replace that gauge? I know that speedhut can sell just the gauges if you don't need the whole kit.
Enthusiast Joined Oct 8, '03 From Cleveland Currently Offline Reputation: 0 (0%) ![]() |
What i did to my gauges which people may not like the idea but, like coomer, i popped off the black cover at the base of the needle and sanded it down a little bit and used some super glue to make sure the covers stayed on. Make sure you dont overdo the glue though
good luck if it isnt fixed already |
Enthusiast ![]() ![]() ![]() Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) ![]() |
You can also widen the hole on the gauges a little but be careful not to damage them. You cannot take off the needles on a celica. However the do slide over your needles. Its usually that the whole for the needle on aftermarket gauges arent quite wide enough a littl ebigger and your golden.
Enthusiast ![]() ![]() ![]() ![]() Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) ![]() |
are u sure u cant take off the needle??? no way? or is it just easy to break |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
yea, my speedo needle has trouble going from 70-80. I wonder if I could raise the needle up a bit...
yup same here man **** i got a 140 ticket for that lol i thougth i was going 40 but really iwas going 57 LOL im a try to ge my friend to take off th eneedles tomrow ill post up pics and how to if its succesful lOL |
Lo-Fi Version | Time is now: April 24th, 2025 - 7:17 AM |
