> camber, i want some ideas
post Jun 7, 2013 - 3:05 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
does anybody have pictures of the rear on a 6gc with some tastefull camber ? preferabbly a silver car, i wanna know what my car would look like if i slammed it
post Jun 7, 2013 - 3:11 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
how would you define tasteful camber?
エキサイティングカーレーシングチーム!
post Jun 8, 2013 - 1:03 PM
snagmor
Joined Jun 26, '12
QUOTE (Reimrod1994 @ Jun 7, 2013 - 4:05 PM) *
http://www.6gc.net/celicas/silly-14230
post Jun 8, 2013 - 4:30 PM
yellowchinaman
Joined Aug 11, '08
From London
mine is subtle at 0.5 rear and 1.25 front.
post Jun 8, 2013 - 11:11 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (snagmor @ Jun 8, 2013 - 11:03 AM) *
If you're going to slam your car. You're going to need camber kits unless you want the natural UBER negative camber. UBER as in enough to notice it a mile away. Lol.
post Jun 10, 2013 - 12:33 AM
mkernz22
Joined May 10, '10
From MA
I have one set of camber bolts in the rear, but I need another on each side. It's too much for me, especially with how high the car still is. The only thing I do like is that it gives it great traction in the rear. It may either way, but I like it right now haha
post Jun 10, 2013 - 11:11 AM
diegohiga
Joined May 4, '09
From coral springs florida US
QUOTE (mkernz22 @ Jun 10, 2013 - 1:33 AM) *
Uou mean use 2 camber bolts in each side?? Is that even safe since those bolts are thinner? ?
post Jun 10, 2013 - 12:55 PM
ILoveMySilly97
Joined Mar 8, '12
I doubt its safe to have two camber bolts on each side.
post Jun 10, 2013 - 10:47 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
I've only ever run one smaller bolt up top for camber and most aftermarket suspension systems that drop your car have openings in the upper eyelet designed for shifting the bolt back and fourth. The wedges fit (camber wedges) fit perfectly behind the knuckle and rotate it out. Or you could use a pry bar like me and hammer it down until the wheel comes out to the correct camber lol.
I'm tucking tire right now with hardly any camber.
post Jun 11, 2013 - 6:26 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
only use one bolt.
you shouldnt need more than 2 degrees +/- and thats usually what the bolts provide
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: February 18th, 2025 - 11:24 AM
