> 94 st idle/running issues
post Jun 7, 2013 - 3:32 PM
Kennyb8709
Joined May 23, '13
From chicago
Car: 1994 st manual trans all stock apart from eBay intake on car prior to purchase 140k on the clock.
Background: car was purchased a month or two ago, immediate tune up was done (plugs wires cap and rotor valve cover gasket and pass window switch fixed) also installed HID's and a radio to demo to customers at my work. Car ran tip top for about 2 weeks.
Problem and symptoms: when starting and idle car idles at approximately 500 or lower RPMS. Car stall occasionally when idling after start up. For first few mins of low idle engine will not rev above 1k if I'm lucky. When car decides to cooperate (anywhere from one minute to five) she revs till red line however 1k to 2.5k severely bogs and its slow after 2.5k. Car has almost no power under load. Passing on the highway is next to impossible.
I need some help here people. Any ideas?
post Jun 7, 2013 - 7:10 PM
Kennyb8709
Joined May 23, '13
From chicago
Update: replaced the TPS because the plastic housing was cracked, no improvement. Going to check out the EGR tomorrow because it seems to be sticking until the car warms up.
post Jun 7, 2013 - 8:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
Idle Air Control Valve.
2001 Miata LS 5-speed
post Jun 7, 2013 - 11:15 PM
timdog1720
Joined Mar 4, '10
From Bronx NY
/\ /\ /\ /\ /\ I agree
Always fast and going for the look......
post Jun 8, 2013 - 2:09 AM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
A faulty IAC only affects the car immediately after start up and until the car warms up. When accelerating the IAC has no additional function. Don't know what else it might be but I would dismiss a faulty IAC. Also, IAC will have absolutely no influence on power under load.
How's your throttle body? MAF? CAT? We'll go on after checking all these out.
post Jun 8, 2013 - 2:49 AM
Box
Joined Feb 23, '12
From Warrior, AL
If the IACV is stuck open it'll cause problems after hitting operating temperature. The car doesn't have a MAF, has a MAP though. Those are easy enough to check. Now that I think about it, I'd put my money on the MAP sensor.
post Jun 8, 2013 - 10:22 AM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
Sorry I was a little drunk when I posted that lol!
But if the IAC was stuck open, he wouldn't have idling/stalling issues after a cold start up. He'll have excessively high idles after being warm though and no real loss of power.
I wonder what he has found out about his EGR
EDIT: avoided double post
This post has been edited by IfWeChoose: Jun 8, 2013 - 10:33 AM
post Jun 8, 2013 - 2:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
Like I said I'm willing to bet it's the MAP sensor, as those will cause all kinds of problems if they're not working correctly. When it's acting up, pull the vacuum line off the MAP and see if anything changes. If it doesn't then there's your problem.
post Jun 12, 2013 - 5:26 PM
Kennyb8709
Joined May 23, '13
From chicago
Thanks so much for the replies thusfar everybody,i made a ****ty video of my issues today while i was at work. here is the youtube link! please ignore my amazing camera skills and HD video /s.
http://www.youtube.com/watch?v=0rzL-KxtjQg
post Jun 18, 2013 - 3:42 AM
Kennyb8709
Joined May 23, '13
From chicago
Bump and replacing the IAC tomorrow. Hope that solves it.
post Jun 18, 2013 - 10:47 AM
travisxcore
Joined Mar 24, '11
From 704
Open up your dizzy, and check your pickup. It might have gone bad. I know when mine did my symptoms were:
-Starting issues
-Rough idle
-Misfire
-Occasional dead cylinder
-Bogging down after 3k
-Bogging down under load
Although I had a check engine light for it but I never bothered to check it cause it had been stuck on for a year.
post Jun 18, 2013 - 1:57 PM
Kennyb8709
Joined May 23, '13
From chicago
Ill check it since its easy to get too but I did replace the cap and rotor with my purchase tune up. Like I said though wont hurt to check.
post Jun 18, 2013 - 4:47 PM
travisxcore
Joined Mar 24, '11
From 704
Your pickup is behind the cap and rotor. It looks like rectangular copper plate with a coil pack around it.
post Jun 18, 2013 - 6:43 PM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
Did you ever check your MAP? Do what Box said earlier in the thread to test it.
post Jun 19, 2013 - 6:00 PM
Kennyb8709
Joined May 23, '13
From chicago
checked MAP, MAp was good, replaced IAC and had a small improvement, ended up adjusting distributor (loosening and rotating) and got her back to normal apart from a slightly high idle. im just glad my baby is drivable again!
post Jun 19, 2013 - 6:02 PM
IfWeChoose
Joined May 25, '13
From Charlotte, NC
Sweet man! Distributor was the next thing I was gonna suggest. Good job man!
Lo-Fi Version Time is now: January 10th, 2025 - 8:29 AM
