> Tire size
post Jun 8, 2013 - 9:58 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
I know there's probably so many threads about this but I tried searching and looked through so many threads and couldn't really find an answer.
I'm going to be getting new tires soon as I bought new wheels, and I wanna know if 205/55/16 would be too big for our car? Anybody run this size? Or should I just go with 205/50/16?
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Jun 8, 2013 - 10:16 AM
Nihil
Joined Jul 17, '12
From Slovenia
I got the car with similar dimension (195/65R15, same diameter as 205/55R16) when i bought it, so I guess you shouldnt have a problem using that dimension.
You need to know though, that your speedometer reading is going to be off for a few percent and that the car's handling is going to be different (acceleration, breaking, steering). At least that's what I noticed with that dimension.
post Jun 8, 2013 - 10:33 AM
PegGTS
Joined Apr 15, '13
QUOTE (Nihil @ Jun 8, 2013 - 11:16 AM) *
That's another thing I was worried about, but it should only change it by a few clicks right? I read somewhere that speedos are a little off to begin with anyways, and that sometimes bigger tires put it right on the dot lol. Know if this is true at all? And would the odometer be effected too?
This post has been edited by PegGTS: Jun 8, 2013 - 10:34 AM
1994 Camry - Sold
post Jun 8, 2013 - 11:48 AM
Nihil
Joined Jul 17, '12
From Slovenia
Yes, you're right, only a few km/h. I used an online tire specs calculator (click), where you can see how much things differ between two tire/wheel specs. It says that the tire diameter is 20 mm bigger and the speedometer offset is 3.3%. So if you think about it, it's only 10mm bigger tire and mild speedometer offset.
post Jun 8, 2013 - 11:54 PM
ecks9t
Joined Sep 23, '10
From Irvine, CA
QUOTE (PegGTS @ Jun 8, 2013 - 7:58 AM) *
I am running that size right now with them 7th gen gt-s rims. they run fine. the tire calculator I check from discount tires say I gain about +3mph, but when I go through the radars I have in my city, its accurate to what the speedo reads.
This post has been edited by ecks9t: Jun 8, 2013 - 11:55 PM
post Jun 9, 2013 - 12:04 AM
Box
Joined Feb 23, '12
From Warrior, AL
205/50/16 will make for the closest to the OEM diameter.
2001 Miata LS 5-speed
post Jun 9, 2013 - 6:10 PM
PegGTS
Joined Apr 15, '13
QUOTE (ecks9t @ Jun 8, 2013 - 11:54 PM) *
Alright thanks, do you happen to have any picture of the tires on your car?
1994 Camry - Sold
post Jun 10, 2013 - 10:39 PM
ecks9t
Joined Sep 23, '10
From Irvine, CA
QUOTE (PegGTS @ Jun 9, 2013 - 4:10 PM) *
i could try and grab some tomorrow and post them for you to see.
post Jun 10, 2013 - 11:00 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
55 is too big on a 16" IMO. 50 is going to fit nicer, look better, and feel better in the long run. Better on performance, closest to OEM.
post Jun 11, 2013 - 11:48 AM
PegGTS
Joined Apr 15, '13
QUOTE (ecks9t @ Jun 10, 2013 - 11:39 PM) *
Don't worry about it now, I went out and bought some so not necessary anymore tongue.gif
Thanks for the input everyone, I went with the 55 because I called around a few places and none of them could order the 50's in. I wanted to go with Walmart also because they were a good price for good tires, plus balancing and Road Hazard Warranty, 550$ for everything
1994 Camry - Sold
Lo-Fi Version Time is now: November 26th, 2024 - 3:28 AM
