99 celica 5sfe |
99 celica 5sfe |
Jun 9, 2013 - 11:30 PM |
Enthusiast Joined Apr 25, '13 Currently Offline Reputation: 0 (0%) |
Okay I need some input.. I have a 99 celica gt convertible 5sfe. Now it is getting built, I am wondering any thoughts! So here's the long story after I have done much research I kind of know what I can do now I'm not a big know it all or nothing but my research has led me to the 98+ 5sfe blocks are strong with thicker walls, now I'm putting forged pistons and rods in it, a st205 top end a st205 3sgte head swap now I know about the modifications, it can be taken care of but bottom end I feel that be strong, for top end with the swap and a st205 intake manifold or a grude head off andysautosport for 2g with a intake mani, that way the ports would be more open than the 5sfe I know top end and intake lack but ive researched alot with the bottom end and the 3sgte is a good motor but if you take the turbo away it puts you close to a stock 5sfe honestly, I have big plans for my celica so I plan to drop money in it and arp head studs with the swap for the head, then it's getting turboed with a ct26 until I build top end more but my celica is going to be a gt4 replica now I thought about the swap with the cheaper cost but I feel I would be better off with my bottom end withmodification just because I have a 98+ block for 5sfe with thicker walls there is a website showing pictures of the 98+ block compared to other engines including the 3sgte and it can with hold more power with modification that is, now my celica is going to have alot of the gt4 st205 3sgte parts including the seats, I was wondering about the awd conversion but it would be alot of work and modification but nothing is impossible. So in all I want to know thoughts, I plan on dumping money into this but if I forgot anything which I probably left out ill have to add in!
This post has been edited by chris32880: Jun 10, 2013 - 10:25 AM |
Jun 10, 2013 - 12:56 AM |
you need to do more research, first off, why on earth would you put a 3S crank in a 5S block. thats going backwards! and then you want to put a CT26 on this "fully" built engine? again steps backwards.
im thinking TROLL -------------------- 2001 Celica GT-S Turbo
Jun 10, 2013 - 7:28 PM |
looks like you have a long road ahead of ya!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jun 11, 2013 - 3:24 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Hmmm...a 5sgte? That's got to be interesting.
Jun 11, 2013 - 8:06 PM |
You are all over the place. You need to establish a plan first.
Start one thing, finish it, then start another, finish it... etc. GT-4 conversion requires a Hatchback, not a coupe like you have... Otherwise it can't be called a GT-4 -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jun 11, 2013 - 9:40 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
Did not read after like 2 lines. Needs to broken off into paragraphs.
Pblms: 1. You cant turn a vert into a GT-4 clone 2. CT-26 on a built motor is stupid 3. 3S crank in a 5s block...why have the 5s block at all then? 4. Youre a noob 5. Trollololol. |
Jun 11, 2013 - 9:45 PM |
Enthusiast Joined Sep 25, '11 From GreatSmokyMtns NC Currently Offline Reputation: 3 (100%) |
You are all over the place. You need to establish a plan first. Start one thing, finish it, then start another, finish it... etc. GT-4 conversion requires a Hatchback, not a coupe like you have... Otherwise it can't be called a GT-4 I'd say calling a coupe a GT-4 is the best part of this plan. -------------------- |
Jun 12, 2013 - 3:56 AM |
If I had time and money and didn't live in Cali. I'd go for a 5sgte build. 5sfe block with the gt4 3sgte head. Wander if you can put out more power than a 3sgte? Since the 5s can take a lot more beating and abusing than a 3s. Lol.
Jun 15, 2013 - 11:35 PM |
If I had time and money and didn't live in Cali. I'd go for a 5sgte build. 5sfe block with the gt4 3sgte head. Wander if you can put out more power than a 3sgte? Since the 5s can take a lot more beating and abusing than a 3s. Lol. Okay so to clarify, I have a 98+ 5sfe block, which means I have reinforced flat block that has thicker walls and can withstand more. So with that said eagle rods and forged pistons by cp or arias or whatever it's called. The crank in the 5sfe already comes forged. 3sgte I would go backwards. Bottom end done. Now head, meaning gt 4 conversion, all I'm doing for the gt4 is the st205 3sgte, meaning st205 head swap (3sgte) 540cc injectors cams and valves. And intake manifold and I want gt4 seats I'm custom modifying my interior (I have the 8 speaker package). Now I can go get a 91-93 3sgte mr2 motor for 100 dollars right now and use the head and manifold if it would fit and the ct26 turbo, i dont know if it will fit the 98+ but when I get the bottom end and head done with bigger injectors and do alot of work I plan on running either a gt35 or 40 turbo but I'm curious to if the st205 will bolt on directly without modification since I have a 98+ 5sfe block I found a very useful sticky I will include a link to btw |
Jun 16, 2013 - 2:54 AM |
If I had time and money and didn't live in Cali. I'd go for a 5sgte build. 5sfe block with the gt4 3sgte head. Wander if you can put out more power than a 3sgte? Since the 5s can take a lot more beating and abusing than a 3s. Lol. Okay so to clarify, I have a 98+ 5sfe block, which means I have reinforced flat block that has thicker walls and can withstand more. So with that said eagle rods and forged pistons by cp or arias or whatever it's called. The crank in the 5sfe already comes forged. 3sgte I would go backwards. Bottom end done. Now head, meaning gt 4 conversion, all I'm doing for the gt4 is the st205 3sgte, meaning st205 head swap (3sgte) 540cc injectors cams and valves. And intake manifold and I want gt4 seats I'm custom modifying my interior (I have the 8 speaker package). Now I can go get a 91-93 3sgte mr2 motor for 100 dollars right now and use the head and manifold if it would fit and the ct26 turbo, i dont know if it will fit the 98+ but when I get the bottom end and head done with bigger injectors and do alot of work I plan on running either a gt35 or 40 turbo but I'm curious to if the st205 will bolt on directly without modification since I have a 98+ 5sfe block I found a very useful sticky I will include a link to btw No you do not have a reinforced block. 98+ refers to the camry blocks, not the celica blocks. All celicas are the same from 94-99 block-wise. I said this earlier. Eagle rods don't come for the 5S, only pauter and carillo make rods for the 5s. The rest you have to get the crank machined to accept them which not all machine shops will do. The gt-4 seats are the same ones as your stock ones but with a different cloth on them (color). You need to do more research and read the posts in your own thread for starters... -------------------- 1993 Celica GT Coupe - sold
Jun 17, 2013 - 3:32 AM |
^^^Follow and listen to this guy. He's also in the process of building a turbod 5sfe. ;P
Lo-Fi Version | Time is now: November 29th, 2024 - 8:16 AM |
