> HID fog lights relay problems
post Jun 10, 2013 - 12:25 AM
SameerIqbal
Joined Jun 24, '12
From Toronto, Canada
Hi everyone,
So I installed a HID kit on the car's fogs and I paired it with a HID 12v relay as I am unsure as to whether or not the OEM stock switch wiring can handle the current draw on initial HID start-up. The trouble I'm running into is that when I turn on the fogs sometimes the passenger side turns on and the driver side doesn't and sometimes the driver side turns on and the passenger side doesn't and sometimes they both turn on and sometimes neither of them. Yes i know.. very tempermental.
Playing with the switch eventually turns them both on but I'm wondering if I made a mistake with the wiring which is leading to this issue?
I have attached the installation diagram as reference if you can spot any problems. the OEM foglight switch is inside the car.
open source screen capture
Thanks much in advance.
Sameer
- SameerIqbal   HID fog lights relay problems   Jun 10, 2013 - 12:25 AM
- - SameerIqbal   ^bump   Jun 11, 2013 - 9:57 AM
- - schmooot   something doesn't look right with your relay. ...   Jun 12, 2013 - 11:35 AM
- - schmooot   It should look like that. The relay has to be gro...   Jun 12, 2013 - 11:53 AM
- - azn87   kind of off topic can u post a pic of what the HID...   Jul 10, 2013 - 1:04 AM
Lo-Fi Version Time is now: December 14th, 2025 - 12:17 PM
