slow engine pick up speed 5sfe, engine is not running right |
Jun 10, 2013 - 11:32 PM |
Enthusiast Joined Feb 21, '13 From saskatoon Currently Offline Reputation: 0 (0%) |
i swapped a motor from a 1998 toyota celica into my 1994 celica, the engine is running but in neutral when i try to rev it up it revs up very slow almost like its bogging down and lacking power, motor ran perfect before i put it in. any sugestions?
Jun 10, 2013 - 11:37 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
i swapped a motor from a 1998 toyota celica into my 1994 celica, the engine is running but in neutral when i try to rev it up it revs up very slow almost like its bogging down and lacking power, motor ran perfect before i put it in. any sugestions? Probably missed a vacuum line when you swapped the engines. -------------------- |
Jun 11, 2013 - 12:20 AM |
i swapped a motor from a 1998 toyota celica into my 1994 celica, the engine is running but in neutral when i try to rev it up it revs up very slow almost like its bogging down and lacking power, motor ran perfect before i put it in. any sugestions? Probably missed a vacuum line when you swapped the engines. is there a difference in an obd 2 vacum set up than a obd 1? |
Jun 11, 2013 - 12:33 AM |
Was about to say, there're quite a few differences in OBDII and OBDI. Exactly what those are I can't tell you, but someone here can.
Jun 13, 2013 - 5:34 PM |
Enthusiast Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
Obd2 was created to help with emmissions. Just swap out the intake manifold for the obd1 manifold. It should fix your problem. Unless you damaged a sensor while putting newer used engine in.
Jun 13, 2013 - 5:50 PM |
There were vac line differences between my 94 and 95 5sfe just because one was fed spec and the other was cali spec. You also have to know if there was a difference between those too.
Jun 23, 2013 - 9:56 PM |
so i took it for a drive yesterday and the exhaust sounds way different then what it used to and it is is making a loud noise from the intake like a mis fire almost and has litterally no pick up its lagging really bad, is this something that could be cause by vacuum lines?
Jun 24, 2013 - 7:59 AM |
no this sounds like something way worse. which distributor did you use? the donor engine came right out of donor car into the transplant car correct?
Jun 24, 2013 - 8:27 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Did you mess up the timing?
Jun 24, 2013 - 4:14 PM |
yes it came right out of the donor car but i had to swap the distributor from the obd 1 motor and the wiring harness from the obd 1 motor for it to run, can bad timing cause really bad engine lagg? its to the point where i put my foot down in first gear and hardly moves anywhere...
Jun 25, 2013 - 6:51 AM |
id double check timing,
if vacuum you'd notice the idle. -------------------- 94 Celica GT
Lo-Fi Version | Time is now: November 30th, 2024 - 1:01 AM |
